 Peerless MST Durably and R&D
Caddy_V3
7 posters
Caddy_V3
Caddy_V3
Peerless MST Durably and R&D  Empty
PostSubject: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 2nd 2018, 7:19 pm
So with the (don't even know what to call it lol, go kart on steroids) build we are planning on using:
- A peerless 90 degree left hand gear box
-to a Mst205-545c i have
I have found the specs on the angle box and it's complicated thinking about it.
http://www.peerlessgear.com/node5379.aspx?nid=300861
The interesting thing is that logically these were made for tractor use. or low horse, low rpm, high torque.
same for the most part in the transaxel
Because we are powering them off of a 440 2 stroke Polaris (fuji) engine that I calculated makes around 30 ft/lbs max at around 7,800 rpm.
So in conclusion we are going to be doing some fairly hard stress testing knowing we are going to make a normal peerless run up to 80-120 mph
This will be interesting as to how long until it gets shredded.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 2nd 2018, 8:57 pm
yeah problems with these transaxles is that the shafts inside them have bushings and not oil lubricated ball bearings.  Bushings are great for low rpm stuff, but don't last long in higher rpm and heat situations.
Caddy_V3
Caddy_V3
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 2nd 2018, 9:12 pm
that's what we figured, we are already planing on moding it to have a sump or two,
pump and a atf cooler.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 2nd 2018, 9:13 pm
Yeah I definitely wouldn't leave a single bushing in that case if you're thiniing about reaching those speeds. Wouldn't take long for one of them to get eaten up.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 2nd 2018, 9:22 pm
Have you thought about making your own case and converting from bushings to ball bearings?  Check out a 3 piece wheelhorse transmission.  That'd be a starting point for a homemade housing design.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 2nd 2018, 9:38 pm
Full bearings, or nothing. I just can't see bushings tolerating that kind of abuse. If you MUST use a pancake transaxle, I VERY strongly recommend a Peerless 820 converted for oil. It can take a lot more stress, and ships with a full bearing package. Iron diff carrier, too.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 3rd 2018, 12:16 pm
At that high RPM the chain is likely to break and cause mass havok.  IDK, it just seems like 820s are overrated. Most people who have them say they are just a big MST with a chain reverse, and a 1" shaft that make it harder to find pulleys for it.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 3rd 2018, 1:03 pm
I disagree, like @Doc Sprocket mentioned it has full bearings.  Needle bearings instead of bushings and also ball bearings on the axle.  It actually has a 3/4 input shaft not 1"  the 1" is the axle.  It is much more durable.  Yeah a point of contention is the reverse chain.  While still durable for mudding applications, it is recommended to remove for speed applications.
Unlike it's other "GT" cousins, the 820 does allow you easy shift on the fly.
Peerless MST Durably and R&D  Sig115PROJECTS:
Peerless MST Durably and R&D  Sig214Peerless MST Durably and R&D  Sig314
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 3rd 2018, 1:55 pm
I think no matter what you use, you are going to chooch the tranny after the first gear shift.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 3rd 2018, 4:08 pm
In this case I agree.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 3rd 2018, 5:09 pm
Maybe he should hunt around for some snowmobile or atv drivetrain parts that would handle the power and speed better. If only there was a really heavily built garden tractor transaxle with no bushings or reverse chain and 1 1/8 axles?
Oh yeah a Wheel Horse 8 speed!
Caddy_V3
Caddy_V3
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 4th 2018, 5:40 pm
The engine is coming out of a Polaris sled I have. were using the MST because it's siting around lol. But anyway the idea was to use a sequential mower transmission because the diff will let us do double wishbone suspension all around. And honestly we are probably going to pull it apart anyway and take the chain off, put bearings in and make the homemade pressure oil system with cooler.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 4th 2018, 5:45 pm
Like run CV shafts off each axle and then mount up the double control arm setup to the frame? I don't know, it'd suck to build all that around it just to have the trans fail.
Caddy_V3
Caddy_V3
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 4th 2018, 6:01 pm
Not necessarily, knowing how much space there is we could drop several things into the small area, and Im honestly more worried about heat then poping shifting keys.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 4th 2018, 6:03 pm
I'd be worried about the input shaft bearing/bushing. Or the bushings for the main and counter shaft for that matter. I would think exensive machine work would be required because the bushings should be replaced with bushings.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 4th 2018, 9:22 pm
Just run a live axle with u joints like dune buggies that are powered with motoe cycle engines. They have a middle solid area with bearings and a drive attachment, then after the brackets there is a u joint on each side allowing for wishbone suspension.
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 5th 2018, 9:39 am
The CTLT has spoken!
PostSubject: Re: Peerless MST Durably and R&D    Peerless MST Durably and R&D  Icon_minitimeApril 5th 2018, 10:11 am
Yup!!!!!!!! lol! oh I could use the mst if you don't end up blowing it up ......... i would give ya like 50 bucks for it
» Peerless 820's
» Peerless 777 use ?
» Peerless 822
» peerless 820
» New peerless 206 for 25$
