 peerless 820
cmanlt4000
6 posters
cmanlt4000
cmanlt4000
peerless 820  Empty
PostSubject: peerless 820    peerless 820  Icon_minitimeMarch 23rd 2013, 8:43 pm
just got a peerles 820 brand new from the factory and would like to lock it. pulled it apart and there wasnt the open diff exposed spider gear setup i was expecting (probly should have done some more research before buying) it seems as though the spider gears are inside where the axles meet at the differential. im not sure how to pull the axles out though because the bearings at the end seem to be pressed in. do i unbolt the differential? i dont want to get any of those upgrade kits i just wanna weld poopie and get it over with... cheaply. anyone that has locked these before please help. sorry if i wassnt clear.
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 23rd 2013, 8:59 pm
Talk to Stretch, he has locked 820s before.
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 23rd 2013, 10:27 pm
Bearings on ends of axle should slide off. They may be a little pressed on, with it being new.
Yes the spider gears are inside the diff gear, you can weld them, but they need to be extra clean, lot of hot weld, and welded straight, to prevent the axle from being misalinged/binding. I would weld the two spider gears inside to the pin they ride on, then weld the gears together. Make sure everything meshes together, should not have to force anything.
Here is a vid on how I did mine, not the same as your's, but you can see another way.
https://www.youtube.com/watch?v=N3JuCfSY-Gc
cumminsbayou
cumminsbayou
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 23rd 2013, 10:50 pm
820s are easy to do all you need is a bolt there is a youtube video i watched of some one doing it
cmanlt4000
cmanlt4000
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 10:35 am
so the bearings the axle rides on that are closest to the outside of the transaxle are removable? i cant seem to get mine to budge and i dont wanna break anything. got any tips on how i could remove them? my biggest problem right now is not being able to geth the diff carrier and axles out
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 2:10 pm
Pics?
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 2:31 pm
Give them a knock with a hammer after u loosen everything , not harder than you would hit your own thumb.
cmanlt4000
cmanlt4000
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 2:41 pm
i have pics but not sure the best way to post them to this forum
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 2:46 pm
Get a photobucket or similar.
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 2:48 pm
Theres a few tutorials in the New Member forum.
cmanlt4000
cmanlt4000
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 2:56 pm
peerless 820  Img_0011
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 3:07 pm
Light taps with a rubber hammer might work. Why do you want them off?
cmanlt4000
cmanlt4000
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 3:11 pm
its the only way i can see of taking out the axles and the diff. unless theres something so blatantly obvious that i missed it.
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 4:01 pm
Lift the axle out of the housing.
cmanlt4000
cmanlt4000
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 4:20 pm
yes i realize that is what i have to do but i have to get those bearings loose first, correct?
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeMarch 24th 2013, 4:30 pm
No they should follow.
peerless 820  Empty
Just lift it straight up. Should all come out fine and go in fine.
MurrayMayhem
MurrayMayhem
peerless 820  Empty
PostSubject: Re: peerless 820    peerless 820  Icon_minitimeFebruary 6th 2014, 5:35 pm
Listen, i have a peerless 820, and mine was from an old murray gt garden tractor, 5th gear was broken, and the shifting was rigged, also it whined alot. But i still drove it, i know it sounds harsh but, when i took apart the axle to inspect it, everything was fine, my shifting was a little weird but it was ok. From experience, i'm definetly sure light taps with a rubber mallet won't do crap, i put a towel over mine and hit it with a real hammer, didn't break anything, especially the axles, i mean come on, their 1". Thos bearings should come off, and then unbolt the bull gear. Then do a normal lock as you would in a reg. transaxle, make sure everythings straight otherwise, it will grenade like mine did. It broke the bolts that hold it together, and blew out of the transaxle. When you weld it and put it back together, make sure that you tighten those bolts on TIGHT. Otherwise it'll do the same as mine, and a new transaxle costs alot of money. I consider putting threadlock in the bolts when you put them back in.
peerless 820  Empty
peerless 820
» Peerless 820's
» Peerless 777 use ?
» 820 peerless
» New peerless 206 for 25$
» peerless 700
