| Pull start for Briggs opposed engines. | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4927 Posts : 1944 Location : Kansas
| | | | RichieRichOverdrive Moderator
| Subject: Re: Pull start for Briggs opposed engines. March 10th 2018, 7:01 pm | |
| That's a pretty good idea. I have the MTD deck drive pulley on Mutt, and a fearlessfront style one on Orion. Shoulda found a bigger pulley for the one on Orion lol. | |
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Pull start for Briggs opposed engines. March 10th 2018, 9:07 pm | |
| OK, So how big is the pulley and how hard is it to pull start it? I never did a pull start like this. Mine are usually done with the Techumsa pull start setup bolted to the tin of whatever engine with the cup on the flywheel center bolt and works OK when you start from the compression stroke. | |
| Subject: Re: Pull start for Briggs opposed engines. March 10th 2018, 9:20 pm | |
| Nice post. I honestly didn't know there were posts down here. It may end up in the B&S section, but you don't have to worry about that. | |
| Subject: Re: Pull start for Briggs opposed engines. March 10th 2018, 9:25 pm | |
| On my other oppys I have no issues pulling it. Of course I have quite a bit of arm and body strength lol ( probably from pulling so many times) the compression really does not even matter , it pulls pretty easy. I think it's a 6.5 inch pulley or so. I can get some great rpms from a rope starter and start easier than using a starter motor . But it's not as fast as you have to wind it up and such.
Yeah mighty I couldn't find a section for srudd like this. | |
| Subject: Re: Pull start for Briggs opposed engines. March 13th 2018, 7:45 pm | |
| Thanks, I put a pull string starter on my Tecumseh 10hp, but when I built the engine I disabled the easy start on the cam. Now I have to pull it up to compression stroke, then start it and hope it catches. Is a pain and keep breaking the rope to start it. The starter still works on it which is why I haven't fixed the easy start. | |
| Who is online? | In total there are 45 users online :: 0 Registered, 0 Hidden and 45 Guests
