| Briggs vtwin pull start help? | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
| Subject: Briggs vtwin pull start help? June 24th 2013, 10:45 pm | |
| Has anyone ever made a pull start for a twin engine before and does anyone know if it would pull over fast enough or would it be to much resistance. Thanks | |
| | | Doug Site Owner
| Subject: Re: Briggs vtwin pull start help? June 24th 2013, 10:46 pm | |
| I have seen it done on YouTube before. If your valves are set right it will pull over fine. Just be a bit heavier. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | | Doc Sprocket Site VIP
| Subject: Re: Briggs vtwin pull start help? June 25th 2013, 8:15 pm | |
| The FSM for those engines shows manual start as a factory option, so it certainly is doable. Best bet? Source the OEM parts, and it's a bolt-on affair. | |
| Subject: Re: Briggs vtwin pull start help? June 25th 2013, 8:38 pm | |
| Anytime! (If you need help with part numbers, I may have a diagram).
Say- looking at your avatar... Can I have some detail on what you've done to your rear tires? | |
| Subject: Re: Briggs vtwin pull start help? June 25th 2013, 8:51 pm | |
| Sure what I did was take boat trailor tires and wheels, I took some bobcat skid steer tires I found and cut the sides off and took the tread shortened them and welded chains through the tread and to the wheels. My version of tread overs or tank tracks! Here's a closer pic | |
| Subject: Re: Briggs vtwin pull start help? June 25th 2013, 9:00 pm | |
| That's pretty creative! Do they work well? It'd be really cool to do it with some deep-tread ag tires! | |
| Subject: Re: Briggs vtwin pull start help? June 25th 2013, 9:04 pm | |
| Ya they work great they spin some just because they are old and worn out but makes the track width much better and very good in ruts | |
| | | | Sponsored content
| Who is online? | In total there are 24 users online :: 0 Registered, 0 Hidden and 24 Guests
