 Pull/Recoil starter on 14.5 hp briggs and stratton?
5 posters
redneckrob
redneckrob
Pull/Recoil starter on 14.5 hp briggs and stratton? Empty
PostSubject: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 18th 2011, 10:32 pm
so thats my goal, if anybody has questions comments or want to help, OR have done it themselves with an engine please respond!
pics are appreciated!!!
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 19th 2011, 5:09 pm
got on off an old kohler 8 hp i had to drill a couple holes in the shroud to bolt it up and put the bolt the cup on the fly wheel, actually isnt that hard to pull on an 11 hp but is a beotch when it doesnt wanna start
redneckrob
redneckrob
PostSubject: Re: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 19th 2011, 6:33 pm
if you got any pics or could take some please do so, thank you!
redzz02
redzz02
PostSubject: Re: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 19th 2011, 6:45 pm
hey sorry bud this is the best i can do for now
Pull/Recoil starter on 14.5 hp briggs and stratton? P_002210
you can see the pull start on the 11hp
Pull/Recoil starter on 14.5 hp briggs and stratton? Sspx0030
this is the cup still bolted on the fly wheel and you can see the extra holes drilled into the shroud, i would get you some detail pics but the pull start part is 2hrs away up my camp sorry, just find one that has a cup and not a ratchet like some of the briggs and you should be able to bolt them up and i might have some pics i just gotta look for them
redneckrob
redneckrob
PostSubject: Re: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 19th 2011, 6:55 pm
hey thanks! what im workin off of is using an old honda push mower starter, but ill look for a old rider with one
Jamus
Jamus
PostSubject: Re: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 19th 2011, 9:34 pm
Some of the larger motors on snowblowers are pullstart with a nice big handle also. Might be able to find the part to bolt right on to your shroud.
http://www.rcbashers.com
redneckrob
redneckrob
PostSubject: Re: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 19th 2011, 10:15 pm
will check that out, but i live in Texas and we dont get much snow down here but, that gives me the idea maybe i can find an old generator, most bigger models have pull starts and electric
biscuit
biscuit
PostSubject: Re: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 20th 2011, 12:08 pm
i got a craftsman 11hp and took a pull start off a 3 hp engine i had layin around. i bolted the "cog" on the 11hp flywheel. then i cut the part off the shroud from the 3 hp and welded it to my shroud on the 11hp. i was gonna bolt it, but it sat too close to the flywheel fins. i had some trimming to do to keep it low profile. but it is cool and works great. but i had to take it all off to change out my flywheel. broke on me.
redneckrob
redneckrob
PostSubject: Re: Pull/Recoil starter on 14.5 hp briggs and stratton?   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeJanuary 20th 2011, 10:25 pm
thanks! that helped alot! im gunna probably do something similar, do you happen to have any pictures of how it bolts on to the flywheel?
dylansrockinrigs
dylansrockinrigs
PostSubject: Pull Start   Pull/Recoil starter on 14.5 hp briggs and stratton? Icon_minitimeMay 1st 2012, 5:37 pm
I pull started a 12 horse easily but I broke my wrist trying to Pull Start a 17 horse by wrapping a rope around the pulley and pulling.
» Adding a recoil start to your briggs opposed twin.
» Briggs vtwin pull start help?
» How much weight can a 12hp Briggs pull?
» Briggs And stratton 900 Series I/c ohv
» 16.5hp Briggs and Stratton opposed
