| Biggasmowers "Muckraker" [2018 Build-Off Entry] | |
+6CraftsmanQuad19 AllisKidD21 Double W Cross Ranch RichieRichOverdrive MightyRaze biggasmowers 10 posters |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
Age : 22 Join date : 2016-10-29 Points : 7210 Posts : 4013 Location : Lewisburg, KY
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5749 Posts : 1993 Location : Northern Ireland
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] May 27th 2018, 10:56 pm | |
| Welp the more I fiddle with the guide idlers and pulleys the simpler a right angle gearbox looks. Might see about stuffing one in tomorrow, I just really do not like the way the belt rides askew in the pulley v's, seems more prone to wear . | |
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
Age : 34 Join date : 2013-11-02 Points : 7165 Posts : 2910 Location : New Jersey USA
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] May 29th 2018, 8:57 am | |
| Thanks ! Hopefully it performs better than a belt twist . Cut out the original axle and welded sI ome steel over the axle slot holes. The Murray axle has the coilover mounts to close together for the craftsman frame, but I have the axle I pulled out of it so I will make it with wider coil mounts and a hopefully stronger. | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] May 29th 2018, 9:27 am | |
| Yes it was the blade drive for a Grazer ztr. Curtis branded I think. I took it apart and cleaned the old grease out and replaced all the internal keyways. Should work nicely. | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] June 9th 2018, 6:41 pm | |
| Well, change of plans, again.... lol.
Deleting the RAGB and putting in a 7or 8 hp Tecumseh horizontal shaft engine and convert to a full horizontal drive. Might put in a Briggs horizontal if it's any good once I get it. Getting the engines from my mower bud and it will make this build go much faster and easier to work on. | |
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] June 9th 2018, 9:59 pm | |
| Neat! Should simplify things quite a bit. Is the Teccy pull start or electric? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] June 9th 2018, 10:50 pm | |
| That's what I was thinking a while back. I knew you would come across a horizontal shaft engine. You'll have to do fab work to make it work but the clutch and everything will be much simpler.
How's the search for the other tire going? | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] June 10th 2018, 1:37 pm | |
| I hate that one way ratchet style starter on briggs with a passion. When the engine backfires when shutting off the engine turns backwards just a little bit and breaks the rope. It was a terrible design. This caused a lot of frustration on a tow behind mott mower we had. | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] June 16th 2018, 5:35 pm | |
| Nice! Is the front track width a lot wider than the rear? It sorta looks like it in to picture. Either way, looking good! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] July 4th 2018, 10:29 am | |
| Sorry for not posting much or anything. Been pretty busy last week being in Nebraska and finally got home then got a bad cold so haven't been feeling the greatest but recently I have done some work on this thing. Cleaned the carb and now it runs and idles nicely and put the fenders back on , it has 3 link front suspension now that is full functional and gives about 8 inches of travel up and down with some soft coil overs from a 99 cc Honda motorcycle. Still can't find the other agg tire but oh well it will turn up sometime. Had a sketchy first test drive with no steering, thorttle, brakes or clutch and a flat tire. Used a idler pulley on anew old tranny mount to manually pull the slack out of the belt in 4th gear and feathered the throttle on the engine and it drives! The front suspension is light enough that the engine can lift the frame if I pulled up the pulley to much to clutch it. Needs some steering and a real clutch andable a smaller pulley on the engine so it has more torque but it's getting somewhere. | |
