| Biggasmowers "Muckraker" [2018 Build-Off Entry] | |
+6CraftsmanQuad19 AllisKidD21 Double W Cross Ranch RichieRichOverdrive MightyRaze biggasmowers 10 posters |
biggasmowers Veteran Member
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] July 4th 2018, 10:29 am | |
| Sorry for not posting much or anything. Been pretty busy last week being in Nebraska and finally got home then got a bad cold so haven't been feeling the greatest but recently I have done some work on this thing. Cleaned the carb and now it runs and idles nicely and put the fenders back on , it has 3 link front suspension now that is full functional and gives about 8 inches of travel up and down with some soft coil overs from a 99 cc Honda motorcycle. Still can't find the other agg tire but oh well it will turn up sometime. Had a sketchy first test drive with no steering, thorttle, brakes or clutch and a flat tire. Used a idler pulley on anew old tranny mount to manually pull the slack out of the belt in 4th gear and feathered the throttle on the engine and it drives! The front suspension is light enough that the engine can lift the frame if I pulled up the pulley to much to clutch it. Needs some steering and a real clutch andable a smaller pulley on the engine so it has more torque but it's getting somewhere. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] July 4th 2018, 1:31 pm | |
| - Crazy_Carl wrote:
- Great progress. I hope you post some pictures soon!
I'm with Carl on this one "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] July 11th 2018, 11:30 am | |
| Ok, so here's an update! Need to buy a new front pulley and rig up some steering and a clutch then it should drive, still lots to do but I am making progress but ran out of funds temporarily. Did drive in a straight line to see about pulley ratio and I have decided to go for a 6 inch engine pulley to the 7.5 inch rear pulley and it will go about 10 MPhil roughly in 4th gear. Which for a 5hp engine is pretty good I think | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] July 12th 2018, 12:32 pm | |
| Interesting front bumper there, that oughta keep people outta the way "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] August 15th 2018, 10:22 am | |
| been messing with converting a vertical oppy to a horizontal to go in this thing, so far its going well just cant find the mounting plate and cant figure out the sump pickup. pulled a truck steering box out of an old ford to put in this to have some good steering for once . | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] August 27th 2018, 8:13 pm | |
| Steering is in, and works nicely, still need a drag link. didnt end up getting that engine so it is going to be powered with a predator 212. found some itp mud lites that are 2 27x12x12 and 2 27x9x12, so the 9 inch wide ones will go on this thing and getting them hopefully for 100 bucks. still have 3/4 inch tread on them. | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] September 15th 2018, 9:21 pm | |
| Nice!! What's the rest of the exhaust setup like? Does it go down into a muffler somewhere? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] September 16th 2018, 1:19 am | |
| Right now the pipe just runs down out of the way to keep the heat from under the hood. Right before I took the pics the tie rod came off on one side, so yes my alignment is way off lol. She pops little wheelies in 2nd gear. Any higher and it bogs down if I let er rip too hard. Only goes 7 mph max but for the rear tires having fluid in them it does well. | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] October 4th 2018, 6:27 pm | |
| Nice! I bet the new steering is a nice upgrade. Is this after the front axle repair or before? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] October 15th 2018, 12:11 pm | |
| Neat. Looks way better with those wheels up front as opposed to the tiny Ags, haha. The side exit exhaust looks pretty cool as well. Nice work! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4055 Posts : 870 Location : Phillydelphia
