| Biggasmowers "Muckraker" [2018 Build-Off Entry] | |
+6CraftsmanQuad19 AllisKidD21 Double W Cross Ranch RichieRichOverdrive MightyRaze biggasmowers 10 posters |
biggasmowers Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] April 26th 2018, 12:39 pm | |
| Well looks like the engine is going to be pulled so I can flip it over and remove the mowing hardware and figure out the gearbox setup. A belt twist wpuld be easier..............took off the hood and dash, rest is going to get removed probably too for wiring. | |
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] May 3rd 2018, 6:04 pm | |
| You'd have to do something for a dipstick tube as well. Also I'm not sure how you'd bolt it down to the frame in that configuration. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] May 22nd 2018, 10:50 pm | |
| Hey that looks really good on there! Should look pretty slick with both mounted up. Also that tire appears to have great tread, like it was hardly used almost. Pretty good for free! Haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] May 22nd 2018, 11:02 pm | |
| Now locating the other tire is going to be very hard, as I simply stumbled on this one and the other is somewhere around his 6 acre yard that has dozens of machines and dozens of vehicles and with enough parts to build a battleship buried all over with tons of combines half emerged in the ground . Oh and the amazing wild blackberries that have half inch razor sharp thorns cover the edges of the property. | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] May 22nd 2018, 11:13 pm | |
| - biggasmowers wrote:
- Now locating the other tire is going to be very hard, as I simply stumbled on this one and the other is somewhere around his 6 acre yard that has dozens of machines and dozens of vehicles and with enough parts to build a battleship buried all over with tons of combines half emerged in the ground . Oh and the amazing wild blackberries that have half inch razor sharp thorns cover the edges of the property.
LOL, it actually sounds like fun. Good luck man! | |
| Subject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry] May 22nd 2018, 11:17 pm | |
| Yeah, tomorrow I am getting a trailer and the cub cadet . Hopefully get that running to tow stuff around the yard and mowing . Also I am getting a dyt 4000 from a guy . Might get that mowing and then sell the mtd and keep the craftsman. Options galore | |
