 Biggasmowers "Muckraker" [2018 Build-Off Entry]
10 posters
Go to page : 1, 2, 3, 4, 5, 6  Next
Biggasmowers "Muckraker" [2018 Build-Off Entry] Empty
PostSubject: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 8th 2018, 8:56 pm
Well I really shouldn't but I might as well because the work on it will happen anyway.
Here is my second build off entry. 92 Craftsman lt 4000 off road /utility build named "Muckraker".Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180340
Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180339
Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180341
Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180342
 My plans are to pulley swap it , put the Briggs oppossed in it, new front tires of same size but better off road tread, paint it , give it a rack, front and back bumpers ,better towing hitch, storage, and have the possibility for yard work but a subdued off road machine for my friends to ride that doesn't go to fast . I will keep the rear tires as they hold air and have reasonable tread pattern and depth. Mabye some frame strenghening and skid plates if I get motivated to do that.
-Approved by Doug, 3/18/2018
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 17th 2018, 10:09 pm
Biggasmowers "Muckraker" [2018 Build-Off Entry] Sig115PROJECTS:
Biggasmowers "Muckraker" [2018 Build-Off Entry] Sig214Biggasmowers "Muckraker" [2018 Build-Off Entry] Sig314
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 18th 2018, 11:54 pm
Even tho it just got approvted........ the oppy is mounted, it jas a rear storage "rack" that needs more improvement, and the entire fuel system needs to be cleaned out as it keep a on clogging my fuel filter nd the carb is screwed up. Currently parked in the woods as it stopped running a long way from home and it's so dirty I couldn't get bybwoth just a jet cleaning.
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 19th 2018, 8:04 pm
Well I think I figured out whybthe carb was clogged..... the crank case breather tube fell off of the air box and let a bunch of junk in the carb.
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 19th 2018, 10:28 pm
That sux... Did you get it back out of the woods yet?
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 20th 2018, 3:05 pm
Well yes I just did! The carb had lots of rubber pieces and grass in it. Must have been from a dirty fuel line. It's now running great on zero choke! Got it back and had a slight detour through some mud on the road...Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180111
Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180112 man I have the projects..... I need two transaxles, or Three would be nice, as one of the mtds vari drive system is mucked up, or just like 6 or 7 transaxles to tide me over for a while
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 23rd 2018, 9:48 pm
It runs good now. Made a throttle cable so I can idle it down now . The mowing parts are going to be removed as I got a Mtd mowing and running well . (All it took was a new belt, new front tire,[Still needs a rear tire] un-bent and welded up the screwed up drag link, cleaned the nasty gunk out of the carb,new fuel cable, pressure washed, and it mows!!!! ) the lt 4000 still needs to have some proper wiring done and i found some large cracked that were previously welded and broke again by the axle housing on the frame.Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180126
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 24th 2018, 11:15 am
Looking good, some decent size front tires ever gonna come into play?
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 24th 2018, 11:19 am
Well now that it's not going to mow the yard it might get some bigger paws. I really like the hood and body style, so it might replace the Murray for off road use. Not sure what to do with the Murray as I have a lot of work on it and I am pretty tires of Murray junk. Oh there might be a mtd project coming up as I am parting it out to keep all of the mowing parts as spare for the mowing mower so I will have a frame and u still have the foote and a 12 hp flatty to put on it
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 24th 2018, 11:31 am
Anything is better than a murray, lol.
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 24th 2018, 1:26 pm
Agreed! Never investing time in another Murray, ayp ,MTD or RER frames from now on!
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 24th 2018, 11:14 pm
Craftsmans are made by ayp....
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 25th 2018, 10:05 am
oops .  There was supposed to be a period behind the Murray part. I am only using the ayp, mtd,rer frames now.
Hauled some junk from the garage to my mower hoarding yard and then brought up the red mtd to part out. I have two functioning mowers now and 2 that run but just need new trannys and then 2 that need clutches and steering. There are plans for the mtds frame as a junk off roader for my friends to drive after I pull all of the usable mowing parts and vari drive off and sell the engine to cover some costs of buying them.Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180127
Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180128
Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180129
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 25th 2018, 11:11 am
Nice! Always great to have plenty of spare parts, haha.
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 25th 2018, 11:12 pm
Did some work with it today. I need to hook up some wiring still.
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeMarch 26th 2018, 10:48 am
Forgot that i hadn't uploaded this romp footage from last week. Tried a new video editor and i trimmed and sped up 44 min down to 11 min.
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 3rd 2018, 1:50 pm
So I got my lovely sister to drag the little old Murray RER frame and drop it on the mower trailer that's been hooked up to the muckraker for a week or so and then awhile latter I went out to drive it up to the house so I could start parting it up a bit and realized my abs really didn't like the idea of pull starting the thing. So I am waiting for another person to wonder by to start it for me lol
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 5th 2018, 7:15 pm
Well that sucks.Biggasmowers "Muckraker" [2018 Build-Off Entry] 20180419
Biggasmowers "Muckraker" [2018 Build-Off Entry] 15229710
It just went pop while I was towing the Murray up to the garage.
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 5th 2018, 7:33 pm
RIP....that a spicer?
You’re always saying how you need transaxles. If you paid for shipping and to buy them, I’d pull a few from the junkyard near me, tag em with the number of speeds and what it’s out of if you care, and send em to you.
I know off the top of my head there are a few peerless 900 series, dunno if it’s a 930 920 or some of each, couple 801s, TON of FNRs like anyone needs those lol, and a 6 speed spicer. Spicer would be good to kick around as a backup but the guy would probably cut me a deal on a bunch of em. The more I get the cheaper it’ll all be. Interested? They run about 50 bucks each for the peerlesses
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 5th 2018, 8:56 pm
I can't believe it just broke like that.  Didn't seem like you were stressing it very much at the time.
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 6th 2018, 9:23 am
I do need transaxles,  I might be interested but the shipping could be pretty bad. If you could get them for cheaper I would defiantly be interested.(I need two peerlesses for the lt 4000's and a spicer or peerless for a backup or to put on the Murray in case you were wondering lol)
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 6th 2018, 11:36 am
Lol I’ll ask and see what I can do
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 6th 2018, 12:31 pm
Thanks! I might be able to get around 150 bucks if I sell an engine to a guy so that would go towards the trannys. The more the merrier right? Lol
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 6th 2018, 2:19 pm
Lol I’ve got three spare MSTs at grandmas. Paid 50 each for em. Never know when I’ll need em lol. I have an issue with gears breaking, not cases
PostSubject: Re: Biggasmowers "Muckraker" [2018 Build-Off Entry]   Biggasmowers "Muckraker" [2018 Build-Off Entry] Icon_minitimeApril 6th 2018, 2:53 pm
Lucky lol! I would love a mat 206, had a 205 and it lasted super well until I down shifted way to hard. Biggasmowers "Muckraker" [2018 Build-Off Entry] 2429134702 best one I've ever had. Probably had in in the Murray for 7 or 8 months hehe
Page 1 of 6Go to page : 1, 2, 3, 4, 5, 6  Next
» Duuds Build Off 2018 "The Donkey" aka "Eesel" [2018 Build-Off Entry]
» Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]
» 2018 ATLTF Build off The ATM [2018 Build-Off Entry]
» Budget build murray [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive-
