 Budget build murray [2018 Build-Off Entry]
TheCollector
17 posters
Go to page : 1, 2, 3, 4, 5, 6, 7  Next
TheCollector
TheCollector
Budget build murray [2018 Build-Off Entry] Empty
PostSubject: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 23rd 2018, 4:21 pm
I have a thing for the way old wheel horses look so I'm shooting for the out come of this build to be something like that but with my own twist. This will be built for trail and pulling stuff around on my property.
Rear tires right now do not match but both are 25-10x12
I will be building the frame from 1"×2" steel then over laying the back half of the murrays floor pan.
Although I have had little luck with Tecumseh, its all I got for now so I will disassemble clean and add new gaskets and seals Its a 9hp.
I'm still undecided on the hood and grill I'm leaning to making the hood out of a steel drum barrel.
Budget build murray [2018 Build-Off Entry] 20180223_122313_1
Got the motor all taken apart. Now for cleaning and paint
Budget build murray [2018 Build-Off Entry] 20180223_144818_1
- Approved by Doug, 2/26/2018
Last edited by MightyRaze on December 4th 2018, 9:57 am; edited 8 times in total (Reason for editing : Add pic)
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 26th 2018, 12:12 pm
@Doug, entry looks good.
Budget build murray [2018 Build-Off Entry] Sig115PROJECTS:
Budget build murray [2018 Build-Off Entry] Sig214Budget build murray [2018 Build-Off Entry] Sig314
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 26th 2018, 9:03 pm
Cool idea of putting a big beefy transmission on a light weight frame . Should be really heavy duty! Good luck!.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 26th 2018, 9:37 pm
I'm very interested to see how you will go about achieving a wheel horse look.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 26th 2018, 9:50 pm
Good luck dude!
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 26th 2018, 10:36 pm
Good luck with your build man! You mentioned using a barrel, may end up looking like a steam locomotive!
TheCollector
TheCollector
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 26th 2018, 10:45 pm
Thanks everyone! I will be building a frame for it. This Murray chassis flexed a ton was even cracking from the flex. The idea here is to make a frame out of 1"× 2" tube then mount the dash and upper part of the murrays frame to that. I belive I will be narrowing and taking some of the height off those parts as well.
Your right on the locomotive part might have to change that plan up now.lol
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 9:44 am
Is that your craftsman in your profile pic?  Looks really good, like to see a video on that.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 9:49 am
I have an idea for this build. To safely stay within the frame rules you could weld up a sub-frame like you plan on doing and set the pan frame on top of it. It would be like dropping a body onto a chassis. It might things like motor mounting, floorboards, and dash a little easier to do.
TheCollector
TheCollector
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 1:11 pm
Just called the steel shop up they will have my steel this Friday. Till then I got the engine painted up just waiting for gaskets and seals to arive. I used caliper paint kinda a strange red color. In the pic with all the parts it not that bright its more of the color with just the block.
Budget build murray [2018 Build-Off Entry] 20180227_120048_1
Budget build murray [2018 Build-Off Entry] 20180225_202544
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 1:22 pm
Looks good! Do you think the paint will stand up to the heat though?
TheCollector
TheCollector
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 1:27 pm
Says its good for up to 900 degrees.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 2:26 pm
In the last picture in your post, what's that barbed fitting on the block in between the valve cover and the oil drain plug used for?
TheCollector
TheCollector
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 2:37 pm
Not really sure I got the engine like that. I'm going to block it off. Looking at pics online other engine do not have it.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 3:27 pm
Maybe wiring? My briggs wiring harness runs under the engine.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 3:29 pm
that looks like a crank case vent for a fuel pump
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 3:37 pm
That's kinda what I though too. Looks like you could get a pulse from there.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 4:26 pm
Yes exactly or just a vent to air or carb
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 7:11 pm
You would get a pulse signal from that fitting. Used for a diaphragm fuel pump.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 7:14 pm
What prancstaman said. Dad's old Tec had that and was attached to a fuel pump.
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeFebruary 27th 2018, 8:35 pm
Come to think of it I replaced a blown head gasket in a B&S last summer that had a crankcase vent hooked up to a diaphragm pump. It’s the same principle.
TheCollector
TheCollector
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeMarch 3rd 2018, 8:53 pm
Picked up the steel Friday. I got 10' of 11gauge 1"×2" tube and also picked up a 6"×13" 1/8 plate.
Today i started on the trans to frame mount. I will be mounting the frame to the front side of the trans like some wheel horses are. I also like this because it keeps the C.G lower.
Budget build murray [2018 Build-Off Entry] 20180303_130026_1
Marked the holes to drill.
Budget build murray [2018 Build-Off Entry] 20180303_131932_1
Cut and drilled the mounting plate.
Budget build murray [2018 Build-Off Entry] 20180303_172102_1
Welded the best I could with my flux core. The trigger is going out so gotta fix that soon
Budget build murray [2018 Build-Off Entry] 20180303_174658_1
Budget build murray [2018 Build-Off Entry] 20180303_175802
There is going to be a Gusset added to the side of this mount for more strength.
Budget build murray [2018 Build-Off Entry] 20180303_184947_1
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeMarch 3rd 2018, 9:00 pm
You're a good welder!
TheCollector
TheCollector
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeMarch 3rd 2018, 9:09 pm
Thanks. I'm learning each time
PostSubject: Re: Budget build murray [2018 Build-Off Entry]   Budget build murray [2018 Build-Off Entry] Icon_minitimeMarch 3rd 2018, 9:55 pm
+1 on the nice weld.  Looks like you prepped well.  That's what I always heard.  Smile  Looks good.
EDIT: I just realized the clean removal of the pulley from the hub.  Sweet!
Page 1 of 7Go to page : 1, 2, 3, 4, 5, 6, 7  Next
» Duuds Build Off 2018 "The Donkey" aka "Eesel" [2018 Build-Off Entry]
» Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]
» 2018 ATLTF Build off The ATM [2018 Build-Off Entry]
» Bow Tie Mud Guy : DIXON BUILD [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive-
