| Budget build murray [2018 Build-Off Entry] | |
+13mr.modified MatthewD SebastianAlbrecht TheBeal CraftsmanQuad19 prancstaman AllisKidD21 Buck Double W Cross Ranch Crazy_Carl biggasmowers MightyRaze TheCollector 17 posters |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
Age : 23 Join date : 2018-02-27 Points : 3842 Posts : 1299
| Subject: Re: Budget build murray [2018 Build-Off Entry] May 5th 2018, 1:01 am | |
| Your mower is getting cooler and cooler! Make a step pulley, so you only need to swap the belt between fast and slow, instead of swapping pulleys, belts,..... | |
TheCollector Member
Age : 38 Join date : 2015-04-22 Points : 3732 Posts : 194 Location : Bedias. Tx
| Subject: Re: Budget build murray [2018 Build-Off Entry] May 5th 2018, 1:27 am | |
| Not a bad idea. Once I get to know this trans axle I will most likely find the right gearing with out swapping anything . right now I'm new to the hi- low range. I'm sure the low gears will be almost unusable to me | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] May 5th 2018, 7:22 am | |
| I have a Hi/low on my wheel horse. I see no need for step pulleys although that is a really good idea. i’m topping out around 12 mph in high range and I barely use low range. first gear is still pretty low in high range so I can just drop into that to crawl up something steeper. I guess it all depends on what kind of top speed you’re looking for. | |
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: Budget build murray [2018 Build-Off Entry] May 5th 2018, 10:11 am | |
| That belt cover looks pretty slick, nice work! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Budget build murray [2018 Build-Off Entry] May 5th 2018, 11:17 am | |
| Something I'd suggest is either a torque converter or an MTD's vari drive. They work great unless they are underwater, and that way you could change ratios as you drive. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5749 Posts : 1993 Location : Northern Ireland
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] May 6th 2018, 1:12 am | |
| Had some time today so I got the winch mounted. Next few days will be dedicated to finishing up the bumper. I'm going to have to add stops because the front axle allows the tires to articulate into the winch on this side and the pull start on the other | |
| Subject: Re: Budget build murray [2018 Build-Off Entry] May 6th 2018, 8:28 am | |
| I'd recomend mounting shocks to the axle; keeps the axle from overpivoting, and gives it high speed stability, but doesn't take away the vital pivot in the axle. | |
TheCollector Member
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] May 10th 2018, 11:33 pm | |
| Ok bumper is done still have more welding to to on it and clean up but I will finish that up when I take it all apart for paint. Yesterday I hooked up the rear brake then got to work on the front brakes. Front brake is basicaly line lock and is controlled seperate of the rear this way I can lock the lever down for winching Here are the parts I'm using to make the front brake. Cut the bottom of the shock off to use as a bushing and also the shock mount off the a arm. Lever Homemade tap Only half the hole is tapped so the cable can mate up to the plate till I get the thump screw adjusters. The old ones are broken. And the bumper got the shackle mounts welded on. | |
TheCollector Member
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3557 Posts : 825 Location : In the shop
TheCollector Member
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5092 Posts : 1412 Location : Cleveland,Ohio
