| Budget build murray [2018 Build-Off Entry] | |
+13mr.modified MatthewD SebastianAlbrecht TheBeal CraftsmanQuad19 prancstaman AllisKidD21 Buck Double W Cross Ranch Crazy_Carl biggasmowers MightyRaze TheCollector 17 posters |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 10th 2018, 11:12 pm | |
| I will be looking at trying to use those mounts when I'm further along in the build. I'm still not sure if I will be using a pan style seat or a riding mower seat. Also im still unsure of the rear fenders. Today I started to work on and mock up the front end and its looking a little long. Rear tires are 25" front are 19" and I have a 48 1/2 wheelbase. I'm thinking I'm a little long from seat to where the dash start but when sitting on it it feels good. Any opinions would be appreciated. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 11th 2018, 7:31 am | |
| I think your tractor looks stretched but in a good way and not overdone. Your wheelbase is only 3 inches more than my C-81. That seems reasonable, but what’s important is that the tractor is comfortable and feels good for you. I would really take TheBeal’s advice and connect your frame to the original axle mounts. That’s how that transaxle was intended to be mounted. The aluminum housing may not handle the torque of being mounted to the end of the frame like that. | |
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
Age : 23 Join date : 2018-02-27 Points : 3842 Posts : 1299
TheCollector Member
Age : 38 Join date : 2015-04-22 Points : 3732 Posts : 194 Location : Bedias. Tx
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 20th 2018, 9:19 pm | |
| Man those fenders look pretty good! Really ads to that old school garden tractor look. Also that front axle looks really heavy duty, should be a rugged stup for sure. Great work! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 21st 2018, 8:25 am | |
| Yeah he's going to be a top contender for sure. This thing looks like a stretched old school garden tractor with atv spindles and front brakes. That is really cool.
What's the motor plan? | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 21st 2018, 10:19 am | |
| Hey! Ain't I a top contender???? I mean , I might be in the hospital or dead after my first test drives but still!
I think he had a Tecumseh 10 hp to put in it. | |
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 21st 2018, 10:37 am | |
| - biggasmowers wrote:
- Hey! Ain't I a top contender???? I mean , I might be in the hospital or dead after my first test drives but still!
How much life insurance do you have? | |
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 21st 2018, 11:11 am | |
Idk..... I might wanna get that figured out I guess... This frame is pretty beefy, but that steel is spensive!! Not sure how that makes it a budget build. Lol | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 21st 2018, 1:35 pm | |
| Thanks guys. So far its looking about how I want it. For now the engine is a techumseh 9hp. As for the budget the steel 1x2" steel tube and the 6"×13" plate cost me $35. $10 of that was there labor to cut it. So as it sits a roller that's all I have in it. All other plates and gussets have been cut out of the Murray's pan frame and a craftsman frame. Bumper will be made from a exercise bike. Lol | |
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 21st 2018, 1:55 pm | |
| Excellent job sourcing your metals if you didn't intend to use those frames again!
Biggasmowers, there are a lot of good builds. A few I do feel are top contenders!
Oh, and the opinion on the seat placement from the other day. Whatever feels good for you. I think the seat looks good there.
TheCollector Member
TheCollector Member
TheCollector Member
TheCollector Member
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 28th 2018, 9:15 pm | |
| Got a few things done the last few days. The steering is done other than some steering stops on the axle. Also started the bumper I'm going with a prerunner style of sorts. The steering is a mix or atv parts and stuff left over from the murray. Steering shaft bushing removed from atv. Got the bushing cut out from the mount. Drilled it for a grease fitting and welded it to its new mount. Steering bushing in place and started the tie rods. They are shorted from the atv These are the parts I found for the front steering shaft. Piece of a old go kart axle the old axle mount from the murray and a front wheel bushing from the murray Here is the steering finished up Started on the bumper. Mounting bars from a murray go kart and main bumper from a pressure washer handle. Here is where I decided this thing is way to long Time to take some out of the dash to shorten this thing up Added some angle steel to mount the hood back to the dash And how its sits mocked up with engine and shorten up about 3". I also made the battery mount that you can see in this pic | |
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 28th 2018, 10:33 pm | |
| How's the direct steering work? I tried direct on a mud mower with big front tires and with a large wrench on the steering shaft I could turn the wheels. Of course that was a while ago and I probably mucked something up and didn't do it right | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 28th 2018, 10:37 pm | |
| It feels good. Wont know till it runs but I did direct steer on my craftsman and it was just fine. Gave me more control at higher speeds. I might mess around with the leverage if needed later on. If by the end of the build off I can come up with a pretty compact gear reduction I would prefer that route. I actually started with the stock murray unit but wasnt happy with it. | |
