| Budget build murray [2018 Build-Off Entry] | |
+13mr.modified MatthewD SebastianAlbrecht TheBeal CraftsmanQuad19 prancstaman AllisKidD21 Buck Double W Cross Ranch Crazy_Carl biggasmowers MightyRaze TheCollector 17 posters |
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 3rd 2018, 9:55 pm | |
| +1 on the nice weld. Looks like you prepped well. That's what I always heard. Looks good. EDIT: I just realized the clean removal of the pulley from the hub. Sweet! | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 3rd 2018, 10:07 pm | |
| Looks like some good penetration on those welds. I moved up from flux to stick and I like it better, no annoying triggers or cables that you have to worry about bending. | |
TheCollector Member
Age : 38 Join date : 2015-04-22 Points : 3732 Posts : 194 Location : Bedias. Tx
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 4th 2018, 8:52 pm | |
| Nice work man. Interesting how you are mimicking a wheel horse frame. I think you can incorporate your seat and fender mount into your trans mounting plate too. | |
TheCollector Member
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 6th 2018, 8:50 pm | |
| Looking good! Yeah I don't like the wide hood either. You should find an old dynamark 1036 hood, they are narrow at the back and widens towards the front with cool headlights. Got fenders? | |
TheCollector Member
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 7th 2018, 8:13 pm | |
| I got the hood and grill narrowed up today. Its a little wider than the grill because I noticed after I did one side that the hood was mounted to the dash off to one side about 1 1/2". Next I will add some sheet metal to the sides of the grill . All in all I think this is a improvement . | |
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
TheCollector Member
Age : 24 Join date : 2016-04-12 Points : 5977 Posts : 2645 Location : Indiana
TheCollector Member
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 8th 2018, 8:28 pm | |
| Got some more done on project murr-horse today. That's what the wife calls it. I never planed on all this body work but that's usually how my projects go. Today I added sides to the grill. There where folds on the sides of the grill so I kept those adds to a factory look. Most of this murray was folded and spot welded. Other thing I did was start to shape and clean up the sides of the dash. For headlights I will go with some round ones and place them much like a ford 8n tractor | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5713 Posts : 1402 Location : Central PA
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 10th 2018, 9:38 am | |
| Youre doing good work on this. Question though, will you be using the original mounting point on the transaxle right above the axles? If you can tie those into the frame I think that would be a good thing. | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] March 10th 2018, 11:12 pm | |
| I will be looking at trying to use those mounts when I'm further along in the build. I'm still not sure if I will be using a pan style seat or a riding mower seat. Also im still unsure of the rear fenders. Today I started to work on and mock up the front end and its looking a little long. Rear tires are 25" front are 19" and I have a 48 1/2 wheelbase. I'm thinking I'm a little long from seat to where the dash start but when sitting on it it feels good. Any opinions would be appreciated. | |
