| Budget build murray [2018 Build-Off Entry] | |
+13mr.modified MatthewD SebastianAlbrecht TheBeal CraftsmanQuad19 prancstaman AllisKidD21 Buck Double W Cross Ranch Crazy_Carl biggasmowers MightyRaze TheCollector 17 posters |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5062 Posts : 1412 Location : Cleveland,Ohio
Age : 23 Join date : 2018-02-27 Points : 3812 Posts : 1299
TheCollector Member
Age : 38 Join date : 2015-04-22 Points : 3702 Posts : 194 Location : Bedias. Tx
| Subject: Re: Budget build murray [2018 Build-Off Entry] July 27th 2018, 10:46 pm | |
| Ok small update. Have not got much done had a few days of 104 out and dealing with Saharan dust that blew into texas been a little sick but here is a update on some of the things I got done prior.I did pick up a pan seat so time to make a seat spring or possibly buy one. Engine needs rings so I might wait and see if I can find another engine or go ahead and fix this one. Bottom ring fell apart when I took it out the cylinder. Spindal parts used to make gas peddle Brake part from 3 wheeler Final assembly Gas peddle mouted. Still needs a spring Foot rest finished Picked up a pan seat at a sale for $12. Wheels and hubs painted up How its sits right now. Also switching to ag tires in the rear | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] July 28th 2018, 12:11 am | |
| I will switch them around. This is the 1st time in a month I have pulled it out of my cramped shed. I also mounted the tank, cut the trans tunnel down some, I dont want to go anymore till I figure the seat out. I also have to rework the rear fenders. I want to complete my build this year so not being over ambitious but in the end want a nice clean off road rig.. | |
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3527 Posts : 825 Location : In the shop
Age : 22 Join date : 2016-10-29 Points : 7151 Posts : 3986 Location : Lewisburg, KY
Age : 20 Join date : 2017-06-09 Points : 5458 Posts : 2640 Location : Literally Nowhere, Texas
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5719 Posts : 1993 Location : Northern Ireland
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] July 28th 2018, 10:59 pm | |
| Thanks on the pedal ! Yep final color is white and the belt guard will probably be black and seat black. Had to take the trip to autozone today to hone out my kohler engine so I took the techumseh also. Did a little parking lot honing to save the trip back to get my rental fee back. Lol its all set for ne rings now | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] July 28th 2018, 11:41 pm | |
| A little of both mightyraze she was really into this task.
Cylinder looks good got a nice cross hatch so the rings should seat good I hope. It was class smooth before.
Yep t.p and pb blaster LMAO! | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5299 Posts : 2561 Location : Rochester, New York
| Subject: Re: Budget build murray [2018 Build-Off Entry] July 30th 2018, 7:39 pm | |
| I love the new ag tires on the rear and the gas pedal too. Although the ATC lover in me cries at the sight a little bit. How much does that spring flex. It would be easy to just weld it solid. I think it's a really cool look. | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] July 31st 2018, 12:21 am | |
| Thanks!! The spring is very solid not sure what its from but has next to no flex. I will give it a good stomping and if needed like Carl said I can always weld it solid. As for the 3wheeler it was a yamaha ytm200 and it was in very bad shape from sitting out side so long. | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] September 14th 2018, 8:27 pm | |
| Oh come on man, please finish You’ve put so much work into this and you’re so close. I’d hate to see it end up in the wrong hands or in the scrapyard. | |
TheCollector Member
| Subject: Re: Budget build murray [2018 Build-Off Entry] September 15th 2018, 2:09 am | |
| Project will continue.. I got into a dirt bike accident and tore the tendons and legements up in my wrist same wrist I use to write with and everything.. The last month + haven't been able to even work. Carl your right I am close but I had a lot more planed for this build. I will do my best to get it finished by deadline | |
