| Talk About Anything Thread V2 | |
+10mr.modified muckmudd biggasmowers AllisKidD21 Crazy_Carl CraftsmanQuad19 Doug TheBeal Double W Cross Ranch MightyRaze 14 posters |
muckmudd Established Member
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5331 Posts : 2561 Location : Rochester, New York
Age : 49 Join date : 2016-09-06 Points : 15662 Posts : 10980 Location : Oklahoma
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4928 Posts : 1944 Location : Kansas
| Subject: Re: Talk About Anything Thread V2 March 17th 2018, 9:20 am | |
| Looking good carl!!!! That's a huge , nice machine . Yeah the rack needed to be small but big enough to hold a small tool box and fuel tank. | |
Age : 25 Join date : 2016-07-10 Points : 8585 Posts : 5190 Location : Ontario Canada
| Subject: Re: Talk About Anything Thread V2 March 17th 2018, 11:51 am | |
| LOVE IT! She sounds abosolutely great Carl! It's quite obvious that you put a lot of time into that tractor to keep 'er looking and functioning the way she's supposed to, and you obviously care about it very much, which I think is just great. Neat editing as well, haha. Nice job! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Talk About Anything Thread V2 March 17th 2018, 12:41 pm | |
| Thanks a lot guys. This winter I wanted to go above and beyond the normal preventative maintenance I do to this tractor and tackle some bigger projects that I’ve wanted to get done on this tractor. I’m really proud of it so I wanted to make a really nice video as a tribute to it. It did take several takes, except for the first start part and I tried some new things in Imovie. | |
Age : 20 Join date : 2017-06-09 Points : 5490 Posts : 2640 Location : Literally Nowhere, Texas
Age : 22 Join date : 2017-07-11 Points : 3559 Posts : 825 Location : In the shop
| Subject: Re: Talk About Anything Thread V2 March 17th 2018, 9:03 pm | |
| Ha nice. Dog looks like its having fun anyways. I slowly ran out of gas today after I put the new exhaust on the lt4000 and I thought that it was idling low for a bit. | |
| Subject: Re: Talk About Anything Thread V2 March 17th 2018, 9:43 pm | |
| Well turns out my carb was bummed up from all of the movement and sediment in the bottom of the gas tank went into the carb even tho I had a fuel filter on it. It's not running very long and on full choke. Made it a bit closer to home but it's still spending the night out with the coyotes Had a pitted spot on the lawn boy frame that was bothering me so I laid a bunch of rod on it for practice and filled in the low area. | |
| Subject: Re: Talk About Anything Thread V2 March 18th 2018, 9:01 am | |
| Every now and then a mistake would happen at the machine shop where I worked. We'd do that same fix. Build it up with weld and machine it down flat. Then sand the part to blend the slight color difference. | |
| Subject: Re: Talk About Anything Thread V2 March 18th 2018, 5:28 pm | |
| I was going to blow up an old Briggs and before I could get it running , after a few pops the cylinder froze even tho I couldn't get it to run or heat up. I took a big pipe and gave it some encouragement...... It's not ever going to run now | |
| Subject: Re: Talk About Anything Thread V2 March 18th 2018, 6:53 pm | |
| OK, first. Last night was a pretty sky and yellow sunset. Made the Bradfords almost glow! Now to shoot an engineer. I always see those post about then and now with the placement of the oil filter... Yeah, Come on Chrysler! My wife's old van was so easy and right there. This RAM 1500 4x4. Not so much. To make a long story short, I got a check engine light and my code reader gave me a code that was related to the MDS of the truck. Recommendation for the code was to change the oil, that someone probably put in the wrong viscosity or it was low. I checked it and it was REALLY dark. I was shocked. Dealership never serviced it. Checked the oil life system and it was at 40%. So, I decided screw the dealership and changed the oil. Oil drain was right there easy enough. Not so much with the oil filter. If it was not 4 wheel drive, I guess it would have been fine. Needless to say the filter is above the front diff. I used a styrofoam cup to catch the drips. I was able to catch and divert 90% of the oil spill from the filter removal. Here is the new filter all tucked away up there. | |
| Subject: Re: Talk About Anything Thread V2 March 18th 2018, 6:59 pm | |
| Yep, that's typical of most modern vehicles, horrible oil filter location. I'm surprised yours is a spin on, most Rams of similar age I've worked on have had a cartidge filter. Maybe something to do with yours being the HEMI engine. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 24 Join date : 2016-04-12 Points : 5979 Posts : 2645 Location : Indiana
| Subject: Re: Talk About Anything Thread V2 March 18th 2018, 8:03 pm | |
- I told ya'll rams were bad!!! JK.
Still not as bad as my Impala. It has a built in funnel because the filter is on the side next to the exhaust converter. You unscrew it and the dribbles go down this funnel under the car to spill all over the front engine basket. Either way, always a mess. If this is the worst, I think I will be OK. 16 plugs? Hopefully they are iridium? | |
| Subject: Re: Talk About Anything Thread V2 March 18th 2018, 8:17 pm | |
| Wow that filter is buried. I changed the oil in the firklifts at work this week. The toyota was easy because you could get a pan under the drainplug, and the oil filter was upside down so all the oil drained out of it and made almost no mess. The hyster on the other hand had a side mount filter that was right above a hard to clean motor mount and the drain plug was pointed at the bell housing which made it hard to get the pan in just the right spot to not make a mess. Yeah I made a big mess which is why I pay someone another $15 over what it would cost to do it myself for my car and truck oil changes so I don’t have to deal with the mess and oil disposal. | |
| Subject: Re: Talk About Anything Thread V2 March 19th 2018, 3:35 pm | |
| Yeah I agree with CQ. I think it's kind of a neat little rig, but there's now way it's 100 years old. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
