| Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] | |
+11mr.modified MatthewD AllisKidD21 CraftsmanQuad19 RichieRichOverdrive prancstaman Double W Cross Ranch biggasmowers TheBeal MightyRaze Dave 007 15 posters |
muckmudd Established Member
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4926 Posts : 1944 Location : Kansas
Age : 22 Join date : 2017-07-11 Points : 3557 Posts : 825 Location : In the shop
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] February 28th 2018, 9:26 pm | |
| turn the ID, OD, lenth on the lathe. Then put in it a vise on a bridge port, face off a couple areas to drill, tap, and counter bore for socket head cap screws, cut the part in half with a bandsaw and boom! you've got lock collars. | |
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] March 1st 2018, 1:39 pm | |
| I was describing to you how to make this style two piece shaft collar. https://m.ebay.com/itm/4-1-DOUBLE-SPLIT-STEEL-NEW-CLAMPING-SHAFT-COLLAR-BLACK-OXIDE-SC100D/291794457361?hash=item43f04e1311:g:AH0AAOSwzJ5XYwlQ. You would drill the screw holes before you cut it in half. You can’t drill on a round surface like that but if you spot face it with an endmill first then you can drill for the screws. Were you planning on making the one piece type with just one set screw in it? I prefer the two piece clamps because they have really good clamping power and are easy to remove. | |
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] March 2nd 2018, 1:23 am | |
| Is it true that with the single screw ones that aren't cut should not be screwed into the key way. I'm just curious even though I don't have a full key way. I think before I try to make anything real fancy I will just try to make some of these. | |
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
Age : 22 Join date : 2016-10-29 Points : 7210 Posts : 4013 Location : Lewisburg, KY
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] March 2nd 2018, 12:52 pm | |
| Don't thread them into the keyway. Tighten the set screw down so it makes a mark on the shaft, then drill a little dimple in the shaft where that mark is. You won't have it move then.
I just use the split lock collars, they're way better lol. | |
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] March 3rd 2018, 9:41 am | |
| - biggasmowers wrote:
- Huh. I never thought that would be an issue , but I guess it is . Is there not as much mass industrial production in canada?
I thought Canada only made oil and maple syrup lol. I think they import everything else. | |
Age : 24 Join date : 2016-04-12 Points : 5977 Posts : 2645 Location : Indiana
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] March 4th 2018, 1:40 am | |
| Here's the weld on hub that I made on the lathe welded onto the old sears sprocket. I finally got around to picking up the new foote and tomorrow I want to oil fill it and I have a few questions. Can you leave some of the old grease that is in between the bearings on or will it make a bad slush type thing? What kind of oil should I use and do I need to make little valve or something on top to fill it with oil? I am planning on just using some permatex type gasket stuff. | |
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] March 4th 2018, 1:50 pm | |
| Ok I was just cleaning the gears this morning and looking for chipped ones and stuff. I only found one so I took it out of the parts foote. The rest looks good and fresh but when I was putting it back together I was using this diagram that somebody gave me and I got confused. It might be kinda hard to see but part number 6 in the bottom right of the diagram has those slots for the gear selector slider. I got confused because the foot does not have a gear on that axle with those slots and I forget how to put it back together. Is it a mistake in the diagram or do I just not know what I am doing. I kinda forget how it goes together so help would be appreciated. Another thing is is that when I compress the springs on that shaft all together, part number 6's key falls out. Is it normal? | |
