 Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]
Dave 007
15 posters
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Empty
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 21st 2018, 8:59 pm
muckmudd wrote:
MightyRaze wrote:
I agree with AK.  Looks good.  Looks to be coming along well.
Thank you sir, slow progress but it seems to be working out.
You still have 193 days left. Not half way yet. Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 2240318088
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 21st 2018, 9:14 pm
Yeah and when the summer comes I will have plenty of time. I just have to make sure I order what I need so that everything gets here before the end of it lol. I was originally planning a 9" pulley but 3 inches bigger may not even hurt for a little extra speed. I Think I will get it but I am just concerned that if it is cast it is not 100% centered, What do you think? they are made for flour mills and they do make a set to motorize the mill so it would be spinning fairly fast.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 21st 2018, 9:29 pm
Will that thing even fit?
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 22nd 2018, 10:48 am
You mean between the frame? I will have to measure. It's gonna be tight but I think so.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 22nd 2018, 11:19 am
Wow, my Murray is only 12 inches wide.
I've got my eye on this one.
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Giphy
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Sig115PROJECTS:
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Sig214Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Sig314
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 22nd 2018, 11:27 am
It's 12.5" on the inside Razz Shocked Shocked Ill have to make sure it doesn't contact the front axle.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 22nd 2018, 6:10 pm
Can't get that frame space on a Murray! Another reason I love craftsmans.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 22nd 2018, 7:05 pm
Well I think I'm gonna pick it up, kinda running out of options.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeMay 26th 2018, 6:55 pm
I cut the front axle at an angle today. That will give it about Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Img_2021
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Img_2019
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Img_2020
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Img_2022
10 degrees of KPI. I figured out how I'm gonna mount the axle. I was gonna cut out a section of the frame and drop it in but I decided against that because the frame would be ridiculously tilted. It already has the nose several inches lower than the rear. I won't add any camber but I am not sure how much caster I should put on the front axle when I decide to weld it in.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJune 1st 2018, 5:49 pm
I'd say 8° caster, max. Setting up a drag link can be a complete sh*t show if you go much further. At least if you're set up like mutt is.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJune 1st 2018, 8:48 pm
8 degrees caster off the frame of the ground though? because my frame is tilted quite a bit.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJune 1st 2018, 8:51 pm
Caster and KPI is always measured off of 90°.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2018, 12:09 am
Yeah but 90 degree off the frame or the ground if you know what I mean. Because the frame is tilted forward.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2018, 8:52 am
I would say the ground then if the frame is going to always stay tipped like it is now. Unless you plan on changing the angle of the frame soon, then you'd account for that. Braces look pretty nice. Heavy duty.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2018, 9:33 am
90 from the ground. The axle straight up and down, then tilt it back a couple degrees
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJune 2nd 2018, 7:29 pm
Yes they do. I want this thing solid so it doesn't break when i'm doing 40. I think I will make the king pin parallel to the axle and add 8* or so positive caster. Thanks guys.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 12th 2018, 6:19 pm
Made the king pin holder things haha, now I just need to weld them on. I used the bolts I was going to uuse for the axles but these will work for both so I just need to buy more. Also tacked the axle in place in case I need to mod it. This tractor is a lot higher than I would have liked but that's ok I guess, not much I can do now. And I wanted the frame fairly level.
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Img_2027
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Img_2026
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 12th 2018, 6:25 pm
Looks pretty neat so far, looking forward to seeing the final stance. What size are those bolts? 3/4"?
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 12th 2018, 6:56 pm
5/8 on axles and king pin.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 12th 2018, 7:37 pm
Come on man, sit the frame right on the axle.  Give it some serious rake like an old hot rod!
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 12th 2018, 10:56 pm
I dunno... lifted would give more of a gasser look.  LOL
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 13th 2018, 12:56 am
It would be funny looking and not too practical though, we'll say i'm just going for more of a Gasser look.
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 18th 2018, 9:33 pm
So the front axle is welded soild, just needs some mat black, but now I need to strt work on the steering. I think I will just go with direct steering to avoid further complictations. I have all the rod ends I will need I think, but now I need to fab up some tabs, set the angles, and weld them in.Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Img_2029
Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Img_2028
George Gooding
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 19th 2018, 1:40 pm
Nice
PostSubject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry]   Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] - Page 8 Icon_minitimeJuly 19th 2018, 2:13 pm
Thanks lads!
Page 8 of 9Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
» Duuds Build Off 2018 "The Donkey" aka "Eesel" [2018 Build-Off Entry]
» Budget build murray [2018 Build-Off Entry]
» Rays customs. Build name Oh Deere [2018 Build-Off Entry]
» Bow Tie Mud Guy : DIXON BUILD [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive-
