| Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] | |
+11mr.modified MatthewD AllisKidD21 CraftsmanQuad19 RichieRichOverdrive prancstaman Double W Cross Ranch biggasmowers TheBeal MightyRaze Dave 007 15 posters |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3557 Posts : 825 Location : In the shop
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5092 Posts : 1412 Location : Cleveland,Ohio
Age : 20 Join date : 2017-06-09 Points : 5488 Posts : 2640 Location : Literally Nowhere, Texas
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] May 19th 2018, 10:24 pm | |
| Looks pretty neat so far muck! Wasn't that grille gonna go on something else at one point? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] May 19th 2018, 10:31 pm | |
| Ah, yeah that's what it was. Knew I remembered it from somewhere, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2018-02-27 Points : 3842 Posts : 1299
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] May 20th 2018, 12:56 am | |
| Thanks for the compliments everyone. Tomorrow I will weld the rear axle mounts in place. I bought bolts for the front wheels today. What size should the King Pin bolt be? is 1/2" too small? Also, is it ok that My rear axle is wider than my front will be. I don't think there's much I can do about it at this point but I was just curious. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5329 Posts : 2561 Location : Rochester, New York
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] May 20th 2018, 3:15 pm | |
| How much wider is the rear and the front?
I'd go with a 5/8 kingpin, that's a common go-kart size.
Are those the shaft collars you made? They look good.
I would just take some time and patience and file a keyway into your sprocket hub. You have nothing to loose so it won't hurt to try it. | |
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] May 20th 2018, 4:06 pm | |
| Thanks. I made a dozen lock collars. I don't think I will need them all but I have them. I will do a 5/8 kingpin I will just have to drill the holes at school because I only have a 1/2 inch bit. I started filing away at the hub but it is so wide it is hard to keep the file in. It will take lots of patience. The rear end is 41 and 3/4 from the outside of the tires and I have not made the front end yet but I cut the axle to 25 inches and that's without the tires. With the tires and king pin ect.. I figure adding about 8 inches on each side with the stuff which would put me at 41 inches and that's fine but if it ends up being way narrower like 5 inches narrower than the back is that bad? | |
| Subject: Re: Muckmudd's 2018 Build off "Astro Rat" [2018 Build-Off Entry] May 20th 2018, 10:49 pm | |
| Those bearing mounts look pretty good! With those gussets and stuff it should be pretty sturdy. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
