| Make a Hi/Low Transaxle from a Regular One? | |
B440 Member
Join date : 2014-01-22 Points : 4201 Posts : 226 Location : Thompson, CT
| Subject: Make a Hi/Low Transaxle from a Regular One? March 8th 2015, 11:06 am | |
| Need some ideas here. I'd like to take a typical 5/6-speed Peerless transaxle from a light-duty tractor, and add a high/low shifter. This would give me 10/12 forward speeds. Is there some way to do this? Trans. has input pulley on top like this. | |
| | | | Doc Sprocket Site VIP
| Subject: Re: Make a Hi/Low Transaxle from a Regular One? March 8th 2015, 3:38 pm | |
- Only way I see this happening reasonably is putting a 2 speed gear box before it with like 1:1 and 2:1 ratios or the like.
I concur. Which... Is why I am doing exactly that. There's no way you can do this with a single range tranny without extensive machining. | |
| | | B440 Member
| | | | Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4948 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Make a Hi/Low Transaxle from a Regular One? March 8th 2015, 10:11 pm | |
| What about a dual belt setup with two clutches. You'd have to have some way to lock out the one you aren't using and two pedals I guess. Or, lets say you usually use the high range. Could have a clutch pedal for that belt and a lever for super low gear, depending on how you wanted to use it. | |
| Subject: Re: Make a Hi/Low Transaxle from a Regular One? March 9th 2015, 8:51 pm | |
| - mr.modified wrote:
- What about a dual belt setup with two clutches. You'd have to have some way to lock out the one you aren't using and two pedals I guess. Or, lets say you usually use the high range. Could have a clutch pedal for that belt and a lever for super low gear, depending on how you wanted to use it.
That is a doable option. Its been tried a few times in the go kart world with success. Same would apply here. | |
| Who is online? | In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests
