 how do i make a gas pedal ?
jackduup
dugan978
6 posters
dugan978
how do i make a gas pedal ? Empty
PostSubject: how do i make a gas pedal ?   how do i make a gas pedal ? Icon_minitimeMarch 22nd 2011, 9:34 pm
i need step by step instructions on how to make a gas pedal for my mpwer i attempted making one going right to the throtle on the carb and bent the rod i think i got it bent to wear it belongs but i need instructions on the gas pedal picstures and videos would help alot more
jackduup
PostSubject: Re: how do i make a gas pedal ?   how do i make a gas pedal ? Icon_minitimeMarch 22nd 2011, 9:49 pm
Go on YouTube and look at fearless fronts videos and he shows it ver well. U put a return spring on the carburetor then you hook a cable up to that and connect the cable to a brake lever and the return spring pulls the pedal back up when u press
it down
PostSubject: Re: how do i make a gas pedal ?   how do i make a gas pedal ? Icon_minitimeMarch 23rd 2011, 12:27 pm
I posted pics under my mod MTD build- but here they are again:
how do i make a gas pedal ? Thrott11
how do i make a gas pedal ? File0045
how do i make a gas pedal ? File0046
I dont suggest bypassing the governer when adding a foot throttle - because over revving the stock ungoverned motor can cause the flywheel to explode - with my twin on a murray, it ran well over 30mph with the governer ( top pic) - id suggest springs on both ends of the cable- one for a pedal return- one to snap the throttle closed .
I used a pedal off my old wheelhorse for a gas pedal - it had the two holes already cast in it- a piece of solid round metal to pivot on, drilled out a couple bolts to use as wire lockers ( changed them to mini ubolts)- whole reasoning behind my setup was doing it with stuff i had around- besides the cost of the tractor ($25) i spent nothing else up to this point.
Crazymudder
Crazymudder
PostSubject: Gas Pedal   how do i make a gas pedal ? Icon_minitimeApril 1st 2011, 8:19 pm
Go On Youtube and watch arild365 he shows great step by step! Very Happy Very Happy Very Happy Very Happy
arild365
arild365
PostSubject: Re: how do i make a gas pedal ?   how do i make a gas pedal ? Icon_minitimeApril 2nd 2011, 1:11 am
hey, Thanks alot man!!! Razz Im gunna make a better tutorial on how to make a gas pedal and another tutorial on how to put bigger tires. In the last vid i was really young Razz Il take it all apart and put it back together.
dugan978
PostSubject: Re: how do i make a gas pedal ?   how do i make a gas pedal ? Icon_minitimeApril 13th 2011, 5:15 pm
arild365 when are you going to make the video
arild365
arild365
PostSubject: Re: how do i make a gas pedal ?   how do i make a gas pedal ? Icon_minitimeApril 13th 2011, 9:54 pm
Il try to make it tonit man. Ive been super busy lately with school and shit. Hopefully shell be up soon! Razz
dugan978
PostSubject: Re: how do i make a gas pedal ?   how do i make a gas pedal ? Icon_minitimeApril 26th 2011, 3:54 pm
all right yea as soon as you have time thanks alot man i apreciate it alot. and please have deep details thatd be helpful and or step by step
canadianromper
canadianromper
PostSubject: Re: how do i make a gas pedal ?   how do i make a gas pedal ? Icon_minitimeDecember 21st 2011, 6:48 pm
yeah go on youtube and look at arild365 and fearless fronts channal and look they have good ideas i looked so that i could build my gas peadle
» M-99 1999 murray wide body
» How do you put a gas pedal on a lawn tractor?
» Gas Pedal??
» gas pedal??????
» Adding a gas pedal- My way
