 How to make extension for transaxle pulley HELP??
Supaflyy
6 posters
Supaflyy
Supaflyy
How to make extension for transaxle pulley HELP?? Empty
PostSubject: How to make extension for transaxle pulley HELP??   How to make extension for transaxle pulley HELP?? Icon_minitimeApril 16th 2014, 8:47 am
I lifted my mower 26 inches, how can I make the transaxle pulley raised about a foot so that it's even with the drive pulley? Any ideas?
PostSubject: Re: How to make extension for transaxle pulley HELP??   How to make extension for transaxle pulley HELP?? Icon_minitimeApril 16th 2014, 10:12 am
Yeah I've done it before, you take the center off of another pulley weld it to some heavy duty pipe or a shaft along with a pillow bearing up top then you mount the pulley on top
http://www.lastdropgarage.com
PostSubject: Re: How to make extension for transaxle pulley HELP??   How to make extension for transaxle pulley HELP?? Icon_minitimeApril 16th 2014, 11:31 am
moved to drivetrain
PostSubject: Re: How to make extension for transaxle pulley HELP??   How to make extension for transaxle pulley HELP?? Icon_minitimeApril 16th 2014, 12:57 pm
I have not done this. If I was GOING to, it would resemble this-
*remove pulley from transaxle
*install 5/8" Lovejoy or other design flexible shaft coupler, or even a U-joint.
*install length of 5/8" keyed shaft into upper half of coupler.
*install two pillow block or flange mount bearings onto shaft, and brace, structurally.
*install pulley on extension shaft
NOTE: the purpose of the coupler or U-joint is to take up minor misalignments, vibrations, shaft, and chassis flex- without breaking or bending the extension shaft or causing transaxle damage.
PostSubject: Re: How to make extension for transaxle pulley HELP??   How to make extension for transaxle pulley HELP?? Icon_minitimeApril 16th 2014, 1:00 pm
First we need to know if you have a welder and so on, just about 50 ways to do it.
PostSubject: Re: How to make extension for transaxle pulley HELP??   How to make extension for transaxle pulley HELP?? Icon_minitimeApril 16th 2014, 4:34 pm
i personaly used a 2" shaft coupler, a pillowblock and some 5/8" shaft and moved the pully up
» [24] FullerBoyz Lily of the Trail
» Make a Hi/Low Transaxle from a Regular One?
» Pulley on transaxle
» Best pulley ratio to make mower spin the tires
» How too Pulley swap a fnr transaxle
