 Best pulley ratio to make mower spin the tires
redzz02
Austin_Gore
9 posters
Go to page : 1, 2, 3  Next
Austin_Gore
Austin_Gore
Best pulley ratio to make mower spin the tires Empty
PostSubject: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 9:40 am
What is the best ratio to get a mower to spin the tires on asphalt
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 9:56 am
FAR more needed than pulley ratio.  Weight distribution, tires, horsepower needed.....
Best pulley ratio to make mower spin the tires Sig115PROJECTS:
Best pulley ratio to make mower spin the tires Sig214Best pulley ratio to make mower spin the tires Sig314
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 10:01 am
X2
Also I don't think it's completely neccessary to start a new thread everytime you have a question... If you have a lot of questions, you can ask them all in just one thread or better yet, do a bit of searching and try and find some answers for yourself. There's a lot of knowledge out there. Best pulley ratio to make mower spin the tires 2731072446
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 10:02 am
please enlighten
Austin_Gore
Austin_Gore
i have looked already and ok
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 10:15 am
Not trying to avoid the question, as this isn't something most of us are looking to do.  If you have facebook, look up Sprockets Garage.  Most of those that use to be here are there now.  Shoot them the question too.  May get a faster response.
I know for me personally since I am a bigger guy, to do so, I would have to leave the trans Unlocked and do a one wheel peel.  If you have smaller slicks and you are a light kid.  You may be able to get away with a 1:1 ratio with an MST or peerless 820 if you rev it high and lean forward.  But doubtful. I know there is a video of a dude doing asphalt donuts going around Facebook.  Judging by his speed in that video, I'm guessing a much smaller pulley on the rear.  But like I said, finding the key ingredients for your/tractor weight, tire grip, horsepower to spin the tires FAST, and not get belt slip I am not sure is an exact science.
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 10:18 am
yah i saw that vidoe and know i want to do it and is there any way to run a chain instead of a belt
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 10:22 am
If horizontal absolutely.  I would check out  carsandcamera's on youtube for some ideas on doing that.  They do a lot of carting stuff and even a tractor once.  Best pulley ratio to make mower spin the tires 2731072446
If a vertical engine.... that would be a whole other animal as chain does not like to run sideways.
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 10:24 am
cause there are idler sprockets and stuff like that i was thinking replace all the pulleys with sprockets and bam chain driven mower
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 11:03 am
That would make it awfully difficult to stop or change gears....
You would need a cen. clutch for sure.
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 11:14 am
yah
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 8:33 pm
You'd need some serious HP to burn the back tires with a lawn tractor. If you just wanna see em smoke you could get them to spin on pavement by hooking the back of the tractor to something solid (low on the tractor so you don't flip over backwards). You'd probably get a little smoke after awhile but I don't know how much fun it would be.
Smaller diameter tires would spin easier. With big tires, I would think there's a big risk of flipping over backwards, even with some serious HP like a motorcycle engine. I think I saw the video you guys are talking about too, that's too risky for my taste lol.
As for gearing, no idea. I guess that depends on how fast you want to spin them and how much power is available. More fun to get a junk front wheel drive car and then spin them by slowly pulling up against a stone wall/another junk car, or something that isn't gonna move and then flooring it. Then you'll get some serious smoke...
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 1st 2019, 10:25 pm
My smart answer is any pulley ratio will make the tires spin on asphalt as when you’re moving the tires are “spinning” but If I know what video you are referring to on Facebook the ground was wet in that video, makes it a lot easier to do donuts and “drift”. my old racing mower would do donuts on dry pavement but it wouldn’t do a burnout. I was a light kid and with a vtwin and 16 inch tires it would do it. Their is no pulley ratio that will make you do donuts and drift on pavement some people get lucky with there set ups and others fail, my best advice is to start experimenting, make your tires rock hard and best of luck
Espyville Mudders
White Trash Productions
Ohio Offroad Mowers
Top Tractor Challenge Host
#StopStretchingTractors2021
Builds: Sears Killer, Mud Dynamark, Drift Missile, 4x4 Dynamark + many more
https://www.youtube.com/user/redzz02
https://www.facebook.com/Redzz02
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 2nd 2019, 12:18 am
Or dump a ton of transmission fluid in your driveway
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 2nd 2019, 8:08 am
LOL ok ill try
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 4th 2019, 9:18 am
i need help taking off all the safetey wiring on my yard machine
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 4th 2019, 9:40 am
Here is a good place to start...
https://www.atltf.com/t2064-wire-diagram-for-most-bs-engines#22718
Many of us rip all the wiring out and start from scratch.
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 4th 2019, 9:43 am
Im not the greatist with wiring i just want the bare minimum on wiring no safety stuff just want the moter and lights
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 4th 2019, 11:15 am
Don't worry, I'm no good with wiring either. Too much for my brain to handle unless it's really simple. A few lights I can rig up though.
Most of the safety switches just ground the ignition coil or to shut the engine off.
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 4th 2019, 11:47 am
i just dont want to do something and not realize it and f up the whole thing
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 7th 2019, 2:53 pm
any one online
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 7th 2019, 2:55 pm
Got a question?
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 7th 2019, 2:56 pm
yes
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 7th 2019, 2:57 pm
Well heck, ask away!
Austin_Gore
Austin_Gore
PostSubject: Re: Best pulley ratio to make mower spin the tires   Best pulley ratio to make mower spin the tires Icon_minitimeOctober 7th 2019, 3:00 pm
best tread for road racing
» What Pulley ratio should i use for running bigger tires?
» What you guys think about this pulley ratio
» Can you make an amphibious mower?
» Best pulley ratio for trail/ torque?
» Would you use a chain or pulley type clutch and what ratio?
