Little enough that I could toss it around like a doll but still need help to put it on the trailer it sits on now. Send me a digital scale and ill weight it for ya.
Put on a bathroom scale. Thats how im gunna weigh the mini anyways.
richie thomas Veteran Member
hell, I top out ours, damn thing only goes to 300, i dont think that would work for me LMAO
Doug Site Owner
So I got to work today tearing this poor bastard apart:
Front axle from it will be going on the Rv2TD, the dash (and probably the direct steering setup) on the Rv1, and the rest for a rainy day. Forgot to grab a picture of just the axle. Oh well.
Gonna have to do some hacking. Tomorrow though, im off today. GT is fully torn down too, the axle looks like itll bolt right in so all I need to do is reinforce the frame since its a cutout.
Got my tires and rims yesterday for the rear. And then what I thought would happen, happened. The tires are too skinny for these fat-arse rims. No way to seal the bead and run them tubeless unless I tube them first and then take the tube out and then put a new valve stem in.
Uhh....
No. So, I ordered a set of tubes for the rears with the special valve stem thats threaded to prevent tube movement. Hopefully that fixes it and the tires dont look ridiculous on the rims, or else I might have to find a trailer rim and new hubs to fit it.
The 4on4 hubs I ordered from BMI were backordered. Aww. BUT! I got a call a few days after placing it and they upgraded me to the powdercoated ones for free (a whole $2 value!). So I got that going for me, should be here next week.
Ordered 5 axle seals for the 820, 2 on each side of the needle bearings and 1 spare just in case. Well... they also got backordered. Email I got said a 10-15 day turnaround until they restock them. Ew, no.
Tore into the 820 today, cause im impatient. Took video, and it uploaded out of sync. Will have to try again. Anyways, its getting fozzy locked, new seals, new reverse chain, oil lube, and vented.
Ordered a 407 piece kit of Orings, and it had 1" ID x 1/8" thickness orings, which seem to be close to Peerless spec. It was cheaper for all 407 than it was for the 5 Peerless OEM. What the hell. Oh well, I can restock what I use, if what I get works.
All in all, its gonna be a busy week next week. I have stuff in the works for a gas pedal that doesnt use a moped brake. Hue.
The gas pedel looks simeller to mine cept i made mine in a whole unit thats re Movable in case i wont to put it on something else one day. Like the build.
Doug Site Owner
