| Need a tach | |
+4GenevaCustoms Jamus Doc Sprocket Garrett Hamilton 8 posters | Author | Message |
Garrett Hamilton New Member
Age : 27 Join date : 2014-04-27 Points : 3871 Posts : 9
| Subject: Need a tach May 1st 2014, 10:04 pm | |
| Where can I find a small engine gauge type tach for less than 40 bucks | |
| | | Doc Sprocket Site VIP
| Subject: Re: Need a tach May 2nd 2014, 7:56 am | |
| - Garrett Hamilton wrote:
- Where can I find a small engine gauge type tach for less than 40 bucks
If you're referring to an analog sweep gauge, you can't- unless you have a horseshoe in your pants. Regular automotive gauges do not work properly with our engines. You can get it to read, but if you actually care about accuracy, then no. Now- cheapest and easiest is the TinyTach- available all over the place. You may also be able to find a cheaper used tach for an outboard motor (marine), diesel (can often be adapted) small motorcycle, or such. | |
Age : 45 Join date : 2010-06-28 Points : 5800 Posts : 511 Location : Southern WV
| Subject: Re: Need a tach May 2nd 2014, 11:06 am | |
| I looked at the tiny tach. I wasn't sure if it would work. BUt ill look into it thanks | |
| | | GenevaCustoms Member
Age : 27 Join date : 2013-09-24 Points : 4409 Posts : 315 Location : Florida
| Subject: Re: Need a tach May 2nd 2014, 1:45 pm | |
| The sunpro super tach III is adjustable to 2,4,6,8,10 cylinders but is huge with a shift light and costs near 100$. There better be another option for my twin because I to want a gauge not digits | |
| Subject: Re: Need a tach May 2nd 2014, 3:48 pm | |
| Yeah same here! And I wont pay 100 for a tach. I want a gauge really. I cant find a single cylinder gauge type tach though | |
| | | kieranruffell Member
Age : 24 Join date : 2014-01-22 Points : 4008 Posts : 43 Location : Whangarei, New Zealand
| Subject: Need a Tach May 2nd 2014, 6:28 pm | |
| I bought one on ebay it seems pretty good for the price although it's pretty slow on updating It was only $15 with free shipping. Have a look around on eBay just search outboard tach or motorcycle tach and you should be able to find them. | |
| | | the54 Member
Age : 30 Join date : 2014-01-12 Points : 4020 Posts : 51 Location : Ontario Canada
| Subject: Re: Need a tach July 28th 2014, 10:26 pm | |
| I did a lot of research on this two years ago... The 68 series by Equus has a tac that works with 1 cyl all the way a 12 cyl. (6068, 7068, 8068) the 6068 being the low end line is around $60 at the time. Theres a button on the back that can be pushed to calibrate the tac to work with any amount of cylinders.
| | | the54 Member
| | | | Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5146 Posts : 1068 Location : New jersey
| Subject: Re: Need a tach July 29th 2014, 8:10 am | |
| Thats a lot for a tachometer What about This one | |
| | | the54 Member
| Subject: Re: Need a tach July 29th 2014, 11:26 pm | |
| - Craftsman1998 wrote:
- Thats a lot for a tachometer What about This one
Hey that's the one I use in my car! There great tachs but like most tacs, there is only a 4,6,8 setting on them. It wont accurately read a single or twin right. | |
| | | Marines2621 Member
Age : 27 Join date : 2012-12-31 Points : 4577 Posts : 215 Location : Mountainburg, Arkansas
| | | | Sponsored content
| | | | | Need a tach | |
| Who is online? | In total there are 15 users online :: 0 Registered, 0 Hidden and 15 Guests
