| How do I wire up a tach to a vanguard vtwin | |
Dipshaw87 Member
![Dipshaw87](https://2img.net/u/2812/37/66/46/avatars/1296-83.jpg)
Age : 29 Join date : 2014-01-02 Points : 4082 Posts : 135 Location : Vanderbilt, Pa
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | Subject: How do I wire up a tach to a vanguard vtwin January 9th 2014, 11:24 pm | |
| I need help wiring up a tach for my mtd. I know that the red wire goes to the positive of the battery and negative to chassis but since I have a vtwin it has 2 magnetos and they're wired together. Do I splice into one of the kill wires or just splice into both to get a reading on the tach? | |
Thunderdivine Veteran Member
![Thunderdivine](https://2img.net/i/fa/i/avatars/gallery/Cine_Seigneur_des_anneaux/Lotr_129.jpg)
Join date : 2012-12-21 Points : 6468 Posts : 2101 Location : Norway, Europe
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | |
MowBandit Member
![MowBandit](https://i.servimg.com/u/f56/18/18/82/33/mowban11.jpg)
Age : 28 Join date : 2013-03-16 Points : 4674 Posts : 477 Location : Haddock,Georgia
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | Subject: Re: How do I wire up a tach to a vanguard vtwin January 10th 2014, 5:07 am | |
| i used a sunpro tinytach 2 and i used the 8cyl setting and tapped into the killwire for both coils and it worked for me now for you it depends jsut remeber all these engines max out at 3600rpm so try the 4cyl 6cyl and 8cyl setting and what ever is closer use that setting now mine was dead on 3600rpm | |
Dipshaw87 Member
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | Subject: Re: How do I wire up a tach to a vanguard vtwin January 10th 2014, 8:34 am | |
| I think I'm gonna get a sunpro tach cause the one I got now is an iequus tach and I can't get the darn thing to work lol I tried hooking it up to both kill wires and it tachs out past 8 grand at idle. | |
![Lawren Wimberly](https://2img.net/u/2812/37/66/46/avatars/1273-1.jpg)
Age : 57 Join date : 2013-12-21 Points : 4730 Posts : 744 Location : Salem Illinois
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | Subject: Re: How do I wire up a tach to a vanguard vtwin January 10th 2014, 1:17 pm | |
| Try hooking it to only one coil kill wire and set it on 4 cyl setting. Vtwins are actually firing the coils 2 times per cycle. Your tach is readin well over twice the rpms of the motor, unless you have removed the governor and are seriously over-revving. Hooking up to only one lead will get ya close
The sunpro mini tach is set up for small engines, and is very adjustable, but you CAN make others work and get them close. DOC Sprocket and I are collaborating on a write up on the subject as we speak.
There are a lot of variables involved
How the tach itself is constructed (I.E. how many pulses is the tach "Looking for" each rev)
is the motor 2 cycle or 4
is the motor 1 or 2 cyl
does the motor's coil ONLY fire on the compression cycle, or does it use the "Lost Spark" method, and fire on the exhaust cycle too.
We'll cover all these things and some solutions in the write up
Last edited by Lawren Wimberly on January 13th 2014, 7:01 pm; edited 1 time in total | |
Dipshaw87 Member
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | Subject: Re: How do I wire up a tach to a vanguard vtwin January 13th 2014, 5:27 pm | |
| I have tried splicing into one of the kill wires from the coil and didn't work and I've tried connecting into both and it didn't read at all so I'm stumped | |
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | Subject: Re: How do I wire up a tach to a vanguard vtwin January 13th 2014, 5:29 pm | |
| - Dipshaw87 wrote:
- I have tried splicing into one of the kill wires from the coil and didn't work and I've tried connecting into both and it didn't read at all so I'm stumped
Not the kill wire, but the light source AC wire. | |
Dipshaw87 Member
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | Subject: Re: How do I wire up a tach to a vanguard vtwin January 13th 2014, 5:37 pm | |
| I have a plug that runs out from under the flywheel and it connects to a voltage regulator then a red wire runs from there to the solenoid to recharge the battery where do I hook it up at? | |
Dipshaw87 Member
Dipshaw87 Member
![How do I wire up a tach to a vanguard vtwin Empty](https://2img.net/i/empty.gif) | Subject: Re: How do I wire up a tach to a vanguard vtwin January 13th 2014, 6:54 pm | |
| That will give a better connection than you think... the HV pulse will cause a magnetic flux field that induces a current in the conductor lead from the tach. as long as the wire is secured to the plug wire (duct tape works fine) it'll pick up. Remember, it's probably firing once per rev | |
Dipshaw87 Member
Dipshaw87 Member
