| 4 link Murray front suspension | |
+9jamcco Creepycrawler mr.modified 1997 Murray Doc Sprocket willis923 rarbaugh07 redlinemotorsportts CornShuck4CE 13 posters |
CornShuck4CE Member
![CornShuck4CE](https://2img.net/u/2812/37/66/46/avatars/1654-21.jpg)
Age : 35 Join date : 2014-04-07 Points : 4162 Posts : 337 Location : Woodville Al
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: 4 link Murray front suspension April 21st 2014, 9:31 pm | |
| Ight den her it is the 4 link murray. This all was dun in about a month out of mostly lawnmower parts and a small atv. Everything was hand made ecept for rod ends tierod ends and shocks. I first mocked it up with turn buckles from TSC. ![4 link Murray front suspension Image17](https://i.servimg.com/u/f56/18/82/17/81/image17.jpg) with bushings in it to take up the slack. This is the first mock up. ![4 link Murray front suspension Image18](https://i.servimg.com/u/f56/18/82/17/81/image18.jpg) Then i hit something hard enough to bend those turn buckles. Since it worked for the most part time to perfect it. So i bought Raced rodends. 5 righthand and 5 lefthand. Then took close mesurments and placed the axel on a 10 degree angle and got my brother inlaw to make the link bars. ![4 link Murray front suspension Image19](https://i.servimg.com/u/f56/18/82/17/81/image19.jpg) i places a 2x4 between frame an axel to extend te wheel base 1an1/2 inch and lifted it 1 inch. ![4 link Murray front suspension Image20](https://i.servimg.com/u/f56/18/82/17/81/image20.jpg) i then built the shock towers and mounted shocks and welded link brackets to axel. ![4 link Murray front suspension Image21](https://i.servimg.com/u/f56/18/82/17/81/image21.jpg) then the link bars come in. ![4 link Murray front suspension Image22](https://i.servimg.com/u/f56/18/82/17/81/image22.jpg) So i proceded to put it together. ![4 link Murray front suspension Image12](https://i.servimg.com/u/f56/18/82/17/81/image12.jpg) I knew i would have to make somekind of shock tower support. But had to go for a ride. After about 5 minets. And one tower about to hit carb it was time to figur out the supports. After a day of ponderin an lookin at it. This is what i come up with. ![4 link Murray front suspension Image23](https://i.servimg.com/u/f56/18/82/17/81/image23.jpg) ![4 link Murray front suspension Image24](https://i.servimg.com/u/f56/18/82/17/81/image24.jpg) After that took it apart and built bumper and painted it and mounted the hood ![4 link Murray front suspension Image25](https://i.servimg.com/u/f56/18/82/17/81/image25.jpg) Hood is removeable with thease removable pins in bumper. ![4 link Murray front suspension Image26](https://i.servimg.com/u/f56/18/82/17/81/image26.jpg) Ind then you have the final product. I redone steering also. But ill do a post in steering for that. ![4 link Murray front suspension Image14](https://i.servimg.com/u/f56/18/82/17/81/image14.jpg) Thanks for your intrest. If you have any questions feel free to ask. And also jamcco asked how much it flexed so here is a pix of it on a 8 inch cinder block. ![4 link Murray front suspension Image27](https://i.servimg.com/u/f56/18/82/17/81/image27.jpg)
Last edited by CornShuck4CE on April 21st 2014, 9:57 pm; edited 1 time in total | |
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 21st 2014, 9:39 pm | |
| Very nice. Glad you did a writeup, something to take note of, nice work. How much travel total can you get if you were to do something simular to a RTI ramp? I get maybe 6" out of my leafs. | |
rarbaugh07 Member
![rarbaugh07](https://2img.net/u/2812/37/66/46/avatars/1443-63.jpg)
Age : 35 Join date : 2014-01-22 Points : 4003 Posts : 117 Location : Logan, iowa
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 5:31 am | |
| How does it steer because I see your tie rod is in front of the axle now. Just curious cause that throws off your Ackerman angle. | |
rarbaugh07 Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 5:32 am | |
CornShuck4CE Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 7:02 am | |
| The steering on it uses spindls off of an older murray garden tracter. That i placed a wider stronger axel in. The spindles where already set up. I didnt need to do any thing accept make to tierod longer and custom fab the drawbar from steering gear. ![4 link Murray front suspension Image28](https://i.servimg.com/u/f56/18/82/17/81/image28.jpg) | |
willis923 Veteran Member
![willis923](https://2img.net/u/2812/37/66/46/avatars/835-97.jpg)
Age : 27 Join date : 2013-04-10 Points : 5687 Posts : 1408 Location : Galway NY
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 7:51 am | |
| thats awsome! great engineering skills! thats actually really well designed. did you do it completely yourself or model it after something? | |
Doc Sprocket Site VIP
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | |
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
CornShuck4CE Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 9:27 am | |
| I did it all myself. I use to rockcrawl toyotas and knew how suspention worked so i just based it off of that. To doc. I recon it still falls under 4 link. The panhard is a stabliser bar. When you talk about 5 link from what i understand. Your mostly getting into. Buggy long travel suspention. Where there are 5 link bars going down to each indevidual tire. Fully indepindent. Thanks for the complaments guys. When i do the rear ill have to take more pix. ![4 link Murray front suspension Image29](https://i.servimg.com/u/f56/18/82/17/81/image29.jpg) | |
CornShuck4CE Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 9:41 am | |
| - 1997 Murray wrote:
- did you mention somewhare that you had an opposed twin? how does that fit with the suspension?
Na i got a oppy on that old murray. 20 hp i think it would fit not sure i know i would have to rebuild shock tower support. i was wonting to build it around a v twin. I dont really care for oppys myself. | |
CornShuck4CE Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 11:36 am | |
| If it does i cant tell it. Ii thought about a 3 link. I just didnt wont the to put one link on one side and two on other. There really aint a whole lot of options of location on a lawnmower. | |
![Creepycrawler](https://2img.net/u/2812/37/66/46/avatars/999-39.jpg)
Age : 37 Join date : 2013-07-02 Points : 4945 Posts : 731 Location : Logan Ohio
CornShuck4CE Member
jamcco Member
![jamcco](https://2img.net/u/2812/37/66/46/avatars/1314-41.jpg)
Age : 25 Join date : 2014-01-04 Points : 4142 Posts : 226 Location : New Hampshire
CornShuck4CE Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 7:55 pm | |
| Lookin good craftsman has a lil more room to work with looks like. Like to see how she turns out. Nice teaser. | |
jamcco Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 8:45 pm | |
| im very close to being done, i just have to get the pan hard held on differently i do need to redo my exhaust now.....just my excuse to make it louder ![Cool](https://2img.net/i/fa/i/smiles/icon_cool.gif) | |
CornShuck4CE Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 8:53 pm | |
| I had to redo mine to. I dont really care for loud exaust myself. I ride in the woods alot and loud kinda sux. I was lookin at your setup and was wondering i you braced your fram any where the links tie on. There is going to be alot of stress there and i know craftsman frams like to buckle in that area. And also you may wont to consider making the parallel of your links wider so it can handle more tourqeing ont the fram and front axel. Also make sure to brace shock tower well. | |
jamcco Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 9:12 pm | |
| yah the frame is going to get braced... ive already had it buckle once. i have some metal ive been looking at doing that with. i also ran some angle iron from shelving down from the front of the chassis to the towers. i think the suspension is solid enough as is i may have to add things along the road, matter a fact i know ill have to add stuff. ill get this done by the end of the week.. i hope | |
CornShuck4CE Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 22nd 2014, 9:31 pm | |
| Allright bubba sounds good. Just remember do it right the first time and you wont have to work on it later. | |
jamcco Member
![Ariens YT11](https://2img.net/u/2812/37/66/46/avatars/482-72.jpg)
Age : 27 Join date : 2012-10-31 Points : 5090 Posts : 745 Location : The Wyo-Braska Panhandle
CornShuck4CE Member
![4 link Murray front suspension Empty](https://2img.net/i/empty.gif) | Subject: Re: 4 link Murray front suspension April 26th 2014, 9:12 pm | |
| Na they are from eye to eye top is like 6-3/4 and bottom is 10 inches. Didnt hit a tree i was flexin it out. I ran off in a ditch and the eye come apart and axel wrapt up under the mower. If you use em weld the eyes closed. | |
