| Front Suspension | |
+12CornShuck4CE Doc Sprocket k2500life FOSWMT redlinemotorsportts dked41 richie thomas Thunderdivine Doug W1ldyOvvnZ truckin42 Kel 16 posters |
Kel Member
Join date : 2013-03-06 Points : 4356 Posts : 75 Location : New Franken
| Subject: Front Suspension April 14th 2013, 9:44 pm | |
| [img] [/img] Above is suspension Junkstar mentioned via Youtube video. This mod was in 2008. You can also fabricate front suspension by using guide bolts, valve springs from a V-8,and valve retainers. | |
truckin42 Veteran Member
| Subject: Re: Front Suspension April 14th 2013, 9:50 pm | |
| That a good idea for front suspension i might do it to my mower. | |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5248 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Front Suspension April 14th 2013, 10:18 pm | |
| Cool looking, you used Mountain bike shocks? | |
Doug Site Owner
| Subject: Re: Front Suspension April 14th 2013, 10:41 pm | |
| If I get another shock, I was thinking of doing that to the Rally since my moped shocks wont fit in with the Vtwin. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Thunderdivine Veteran Member
| Subject: Re: Front Suspension April 17th 2013, 5:46 pm | |
| Nice, this is the same throw I want on my Racer. | |
richie thomas Veteran Member
| Subject: Re: Front Suspension April 17th 2013, 7:24 pm | |
| why not mount a single leaf spring the length of your front axle ?
dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4805 Posts : 141 Location : central Wisconsin
| Subject: Re: Front Suspension April 19th 2013, 12:52 pm | |
| A single transverse leaf spring would not be a simple system. You would need to stop forward and back movement, side to side movement with the shackles. You would have arms and pivot points all over. It would look cool, but a real pain to set it up. | |
| Subject: Re: Front Suspension April 20th 2013, 9:32 pm | |
| - dked41 wrote:
- A single transverse leaf spring would not be a simple system. You would need to stop forward and back movement, side to side movement with the shackles. You would have arms and pivot points all over. It would look cool, but a real pain to set it up.
Think he means instead of those above, so would be easy. | |
| Subject: Re: Front Suspension April 21st 2013, 11:12 am | |
| fearless on his murry mudder has a solid front end. do you think that's good? I kinda want to do it
I locked the front on mine and while the rode is a bit rougher its not too bad. My locker (a 5/16" bolt) actually wore out or something so I have like 1/8" of play. | |
| Subject: Re: Front Suspension April 21st 2013, 1:21 pm | |
- fearless on his murry mudder has a solid front end. do you think that's good? I kinda want to do it
If you wanna get your ass kicked you should, why do you think dune buggies or similar have a throw of 60". - smooth ride. | |
| Subject: Re: Front Suspension April 21st 2013, 10:19 pm | |
| For a front suspension for my mower im gonna do a coil suspension and it all will be flexable. | |
FOSWMT Member
| Subject: Re: Front Suspension September 23rd 2013, 3:40 pm | |
| [quote="Kel"] " /> Above is suspension Junkstar mentioned via Youtube video. This mod was in 2008. were is the vid? | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
| Subject: Re: Front Suspension September 23rd 2013, 4:07 pm | |
| That's pretty awesome my do that to my mowers now | |
FOSWMT Member
| Subject: Re: Front Suspension September 23rd 2013, 4:42 pm | |
| I wondered if anyone had this mod done and a video of how it works? | |
FOSWMT Member
Doc Sprocket Site VIP
| Subject: Re: Front Suspension September 29th 2013, 11:09 am | |
| Try sending a message directly to him... | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4233 Posts : 337 Location : Woodville Al
| Subject: Re: Front Suspension April 9th 2014, 7:50 am | |
| by richie thomas on Wed Apr 17, 2013 7:24 pm why not mount a single leaf spring the length of your front axle ? You cpuld but you would have to have a 4 or 3 link setup to keep the axel in place. | |
CornShuck4CE Member
| Subject: Re: Front Suspension April 19th 2014, 3:27 pm | |
| This is the front of my murray widebody LT. This is the 4 link bars on the side of the frame. This is the panhard bar on front. This is the front look at the motor and shock tower This is the finish product. This is mostly made of lawnmower parts and some off of a chineas atv. I rebuilt the steering and changed it all over to single tierod and atv tierod ends. All link rodends come from www.racingrodends.com. Link bars where custom made out of tool steel. Works great. | |
rarbaugh07 Member
Age : 36 Join date : 2014-01-22 Points : 4074 Posts : 117 Location : Logan, iowa
| Subject: Re: Front Suspension April 19th 2014, 5:03 pm | |
| That is awesome! Great mod very little weight added for the increase in performance. | |
CornShuck4CE Member
| Subject: Re: Front Suspension April 19th 2014, 6:12 pm | |
| Thanks alot. I wonted to keep it as original lookin as possible. Your build sparked alot of ideas as well. I had thought of mounting tranny on its side how does that work out. The hardest part of the front suspintion was working out the shock tower and how to support it and keep it all under that small murray hood. | |
rarbaugh07 Member
| Subject: Re: Front Suspension April 19th 2014, 7:16 pm | |
| Ya same here was going for the stock look. Trans works great and you could run any style of suspension with it that way. | |
jamcco Member
Age : 25 Join date : 2014-01-04 Points : 4213 Posts : 226 Location : New Hampshire
CornShuck4CE Member
| Subject: Re: Front Suspension April 20th 2014, 8:37 pm | |
| Im impressed CornShuck! Nice work, i think that is a first in the tractor modding world. Slick work, are you going to get different shocks or leave it?
jamcco Member
| Subject: Re: Front Suspension April 20th 2014, 8:38 pm | |
| ok thanks also do you know how much flex you have with the shocks (i have the same shocks laying around) | |
