 Question about independent front suspension
5 posters
Nevadablue
Nevadablue
Question about independent front suspension Empty
PostSubject: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 8th 2022, 11:07 pm
What if one took a front axle from a Craftsman mower, one of the pressed steel welded assembly ones, not the cast iron one… and cut it in half in the middle. Then make a pivot point on each half, near the center cut. Then mount those on the frame with something like coil over motorcycle shocks on the outboard ends. It will probably need a beefed up box, similar to or the same as the original axle box.
Just thinking, independent front suspension looks like it would be good.
Thoughts?
I think I stole this image from one of RCG’s videos. Anyway, cut in half, remove the red area in the middle and drill some holes.
Question about independent front suspension 03456310
PostSubject: Re: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 8th 2022, 11:22 pm
Actually, I think @Murraymountain is doing that very thing in one of his builds right now!  I think @RCG did like @AllisKidD21 and did ford style twin I-beam.  Long as it is braced good, I see no issues?  Just need to find a way to keep it wobbling forward and back.
Question about independent front suspension Sig115PROJECTS:
Question about independent front suspension Sig214Question about independent front suspension Sig314
Nevadablue
Nevadablue
PostSubject: Re: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 8th 2022, 11:51 pm
I’ll do some snooping on the site.
You are right, it would probably need a hairpin on each side.
RCG
RCG
2016 Build-Off Finalist
PostSubject: Re: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 9th 2022, 8:41 am
Nevadablue likes this post
http://www.Mudmower.com
Nevadablue
Nevadablue
PostSubject: Re: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 9th 2022, 11:36 am
Thanks!
I had missed a bunch of your videos. You also confirmed my idea of putting real bearings on/in snowblower wheels. Good stuff!
TechnoChicken
TechnoChicken
PostSubject: Re: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 9th 2022, 12:22 pm
That's exactly the idea I had... Thinl it should wwork though?
RCG
RCG
PostSubject: Re: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 9th 2022, 1:26 pm
Also wanted to add a google term for you to do your homework on. "MacPherson Suspension"
This was the type I was debating pre switching to the Ford twin I beam design.
Another type I debated was J arm but after reading up on several off road reviews on machines that had used it in the past decided not to go that route.
Nevadablue
Nevadablue
PostSubject: Re: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 9th 2022, 2:22 pm
This is probably about as simple as a MacPherson setup could be done. Many have a lower A frame, but this one is essentially what I described in the first post with an added torsion bar. The torsion bar could be replaced with a hairpin or radius rod setup.
Thanks for the idea, I like this one.
Question about independent front suspension 84e85510
PostSubject: Re: Question about independent front suspension   Question about independent front suspension Icon_minitimeJanuary 9th 2022, 6:51 pm
Yep! Just did this on the MM last year. Definitely should work if done right!
» Front Suspension
» Front Suspension
» Front axle question on my old wards
» Front Suspension Ideas
» Crazy Front Suspension Ideas
