 BKC's Craftsman Build
jamcco
camomanusa
Moose
TroyBilt Pony
Craftsman1998
bry_93
13 posters
Go to page : Previous  1, 2, 3, 4
bry_93
BKC's Craftsman Build - Page 4 Empty
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 1st 2014, 10:00 pm
Hey I Got Another Wire Brush Today For My Grinder Didnt Get The One I Wanted Cause After 5 Hardware Stores They Apparently Dont exist Anymore But I Think It'll Work So I'll try & get Up Early In The Morning & Get The Grille Cleaned & Tack Everything Together & Whenever He Gets Time My Dad Is Gonna Use The Stick Welder on It To Kinda Fill It In Some So It'll Take Very Lil Bondo To Cover The Seems Up & Save Allot Of Wire
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 2nd 2014, 9:47 am
Hey This Is Off Subject But I Wonder How Much Power/Torque The Rearend From I Think Its An 830 husqvarna Lawn Tractor Can Handle Its The Side Shaft With Splined Axles & 5 Lug Wheels Not Sure What Type Of Rearend It Is Cant See A Name & Its Not Mine Yet So Dont Want To Take It Apart To Find Out But More Specifically I Wonder If It Could Handle 121Hp & 89Ftlbs & Not Bein Abused Much
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 2nd 2014, 10:27 am
ummmmm I don't think it will. however, I know that that is one of the strongest trannys ever built, so it might for a little while.
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 2nd 2014, 7:01 pm
Ok Thank You I Wanted Something To Limit The Motor & Have Reverse For Car Shows Thank You
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 2nd 2014, 7:13 pm
i Got The Grille Cleaned & Put It All Back Together So Tomorrow It Can Be Welded Together & Very Happy To Say The Motor Started It Aint Bolted Down So Couldnt Let IT Run But It Did Start
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 3rd 2014, 7:24 pm
So Gonna Try Somethin I Got A 2 1/2in Pulley For The Rearend Then My Dad Remembered He Made A Pulley In School Thats A 1.in3/4 So Gonna Try That The Lowest I've Went Is 6in. So Dont Know What To Expect But After Figuring Everything It Should Be Every time The Motor Turns once The Rear Wheels Will Make 1 Complete Rotation So 1to1 Engine To Wheels & 1to3 Engine To Rearend
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 4th 2014, 9:45 pm
Started Gettin The Hood & Stuff Welded Together & Ran Out Of Wire So As Of now Its Just Kinda Welded Together
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 5th 2014, 3:04 pm
i know that feeling man, i was workin on the lift on dixie last year and had just barely got a good tackweld, and ran out of wire,thats why i started keeping a spare roll in the toolbox lol
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 6th 2014, 11:18 pm
That Would Be A Really Good Idea Since I Live 30mins From Town But I Got Some Next Day & Got It Welded Then Remembered There Was Some Wire In My Old Welder But Thanks For The Idea
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 14th 2014, 9:54 pm
i Finally Got Time To Work On It Today & Got More Done Than I Was Planning Since It all Went Well But I'll Get Pics Tomorrow I Got The Hood Trimmed & Mounted Then Got The Bolts Out Of The Motor Since The Scrap Yard Cuts Them With A Torch Then Then Happened To Have Some Bolts From A Camry That Fit & Got Lucky & The Kohler Fit The Briggs Bolt Holes On The Craftsman Frame But It's Coming Along Nicely
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 16th 2014, 11:08 am
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 16th 2014, 11:12 am
I Didnt Put This With The PIcs Cause last Time It Made The Links Stop Working & Had to redo All Of Them But The Pics Are Of The Hood Mount & The Were Everything Is Welded Together & The Motor Bolted Down & What It Looks Like With The Hood & Fenders Mounted Thanks Sorry I Was A Day Late On Pics But It Went From 65 To A Couple Hours Later Have'n A Lil Blizzard All Day Yesterday
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 16th 2014, 1:09 pm
Nice Hood and Grill!
- And as a FYI, You are supposed to put an Image code infront and the back of each picture link. This so we don't have to click on each link to see the pictures.
[ img ] https://i.servimg.com/u/f57/18/68/45/50/00416.jpg [ /img ]
Example:
BKC's Craftsman Build - Page 4 00416
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 17th 2014, 12:56 am
Thunder Thank You & Didnt KNow That I'll try It Next Time Thanks
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 17th 2014, 11:03 pm
I Got The handle Thing Back On For The Deck Height Adjuster Hadf To Move It some To Clear The Hood but Gotta Finish the Cables Up Then The deck Will Be Done & I Got Very Lucky Again & Since the Pulley On The Kohler didnt Line Up With THe Pulleys From The Craftsman But I Happened To Have the Pulley From The Craftsman & It Fit THe Kohler Shaft & It Lined Everything Up So That Was Awesome It Wont Be Long & Should Be Able To Do A Test Run
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 19th 2014, 9:44 pm
Should make a cool grass cutter. Nice hood.
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 21st 2014, 9:24 am
Thanks I Figure If Nothin Else You Aint Gonna See Another One
bry_93
PostSubject: Re: BKC's Craftsman Build   BKC's Craftsman Build - Page 4 Icon_minitimeApril 26th 2014, 11:22 pm
i'll See About Gettin PIcs Tomorrow But I Got The Cables Finished For The deck I Drilled Holes In The Arm & Put A Bolt Through It Then Put THe Cable Around It So It'd Pivot Still on the deck SideBut Um IF Your IN The Area Probally Gonna Bring It OUt To THe Shopville Ky Tractor Show With My Other Mowers If You Want To Come Check It OUt
Page 4 of 4Go to page : Previous  1, 2, 3, 4
» cjs's craftsman build
» Craftsman Build
» craftsman build
» Craftsman GT becoming something.. My first ever build
» Craftsman GT-18, or JD 111. Which should I build?
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2014 Archive-
