| BKC's Craftsman Build | |
+9jamcco redlinemotorsportts camomanusa Moose TroyBilt Pony richie thomas Craftsman1998 Doc Sprocket bry_93 13 posters |
bry_93 Member
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4948 Posts : 919 Location : Defiance, Ohio
| Subject: Re: BKC's Craftsman Build February 9th 2014, 7:16 pm | |
| kohler looks good tranny looks like it could use some oil though lol or some good ol axle grease! | |
| Subject: Re: BKC's Craftsman Build February 9th 2014, 7:31 pm | |
| I think ive seen this on facebook (?) you were selling custom frames for lt craftsman's? | |
bry_93 Member
Age : 31 Join date : 2014-01-02 Points : 4053 Posts : 78 Location : somerset, ky
| Subject: Re: BKC's Craftsman Build February 9th 2014, 8:11 pm | |
| moose it defintley could you should of seen it before everything in it was rusted up & stuck & RedLine Yes Indeed You Did See It On FaceBook The Frame Is Just A Universal 1 For Pretty Much Any Mower The Body Was Just Sittin On It For The Pics I Wanted To Do The Build Off & Needed To Build One Usin The Frame So Just Combined The 2 | |
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 10th 2014, 2:56 pm | |
| i'll get ya some pics later but i got the dash mounted & just sat the motor on it to see what it'd look like | |
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 10th 2014, 6:29 pm | |
| sorry ill have to wait till tomorrow for the pics might have more done by then | |
bry_93 Member
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4576 Posts : 467 Location : Greensburg, PA
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 13th 2014, 9:20 am | |
| I'm Hoping Theirs Enough Room I can Flip The rear-end upside down & sit it on top of the frame just don't think with the deck i can go that low we'll see though | |
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 13th 2014, 8:18 pm | |
| my camera battery went dead after 1 pic so in the morning i'll get pics But I got the brake rod in it with some cuttin & modifying It Works Great & i Went Ahead & Put The Deck Height adjuster on The Dash If I Have Time I Might Be Able To Get The Deck Mostly Under It Tomorrow | |
bry_93 Member
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 14th 2014, 4:28 pm | |
| i got started puttin the deck under it but i gotta wait & get a set of cables to put in place of the rods on the height adjuster since they dont fit anymore then it shouldnt be that bad to put the rest of the brackets on | |
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 14th 2014, 7:51 pm | |
| thanks redline yea ive got another thats a few years older i done fixed it up but it works really good im hopping that changin the pedal to were u have to push it to go helps takin off with direct drive rearend | |
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 15th 2014, 9:17 am | |
| Its Snowing Pretty Good But If I Get To Go To Town Today I'll Get THe Cables For Deck Their 8.99 Not Bad With Alil Modin Should Work Good | |
camomanusa Member
bry_93 Member
bry_93 Member
| Subject: update February 15th 2014, 1:29 pm | |
| i think i figured out a way i can use some cable i already have for the deck & still look good & work good & i'll get ya some pics later but i did some more work on my rearend a gear was slippin on its shaft so welded it up & it worked great so then decided to weld the spider gears so now both wheels turn & it seems to be workin really well now i just gotta fix the top of the case were its broke but i'll get some pics as soon as i can today thanks | |
| Subject: Re: BKC's Craftsman Build February 15th 2014, 3:15 pm | |
| I think you can get the tops of the cases from sears for cheap not sure though depends on the tranny
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 15th 2014, 8:52 pm | |
| Ok Thanks Moose I'll Check If Its Cheap I mIght Just Do That Cause Its pretty Bad | |
bry_93 Member
bry_93 Member
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 16th 2014, 6:53 pm | |
| ok so wasnt really plannin on it but i've been tryin to use a certain hood & it never looked right but i sat it on this 1 & its pretty cool so its probably gettin a ford 8n tractor hood & grille it fits it very well i'll get the grille & fenders on the hood & get a pic tomorrow | |
camomanusa Member
bry_93 Member
| Subject: Re: BKC's Craftsman Build February 18th 2014, 9:09 pm | |
| camoman its doin pretty well since its gonna be good & warm im gonna try & get up early tomorrow & finish the rearend case put some fake steel on it should only take a few mins then while its dryin put the front axle on it since its goin underneath gonna use the factory mount maybe put some springs on it to help it rockin with weight of the hood then if i got time maybe work on gettin the rearend under it | |
bry_93 Member
