| 60's Springfeild Mini Speed Tractor | |
+28Mitch'sgarage GenevaCustoms dwcopple MurryMaddnes Khal03 Stretch44875 Angchor jsisti845 untrusty huskee craftsmancole kawasaki220 willis923 T-Dub13 the craftsman mudder mr.modified Doug Craftsman1998 TheBeal jack9102 LAWN MOWER MUDDER TroyBilt Pony Lawren Wimberly Doc Sprocket Thunderdivine richie thomas 1997 Murray camomanusa redlinemotorsportts 32 posters |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 13th 2014, 7:52 pm | |
| Update time. Mocked this up so i can get a feel for spacing and what else i need. i think im going to get a smaller gas tank. cramming all the junk. More clear picture of sprocket. Gunna make a good chain guard... #nofenderswag Now onto the hood (yesterday and todays project) Looked a little to "wheelhorse" like i just slapped a hood on it, looks kinda tacky concerting it ISNT a wheelhorse. So i modded the grill after a idea of some hot rods popped in my head. Creepycrawler, close your eyes. Cutting carefully.... Weldy weldy, tacky tacky! Majority of it done Filed down every single weld to make it perfect! Headlight and decorative piece removed, paint stripped and primed white to prevent rusting. | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4576 Posts : 467 Location : Greensburg, PA
richie thomas Veteran Member
Thunderdivine Veteran Member
| Subject: Re: 60's Springfeild Mini Speed Tractor April 14th 2014, 2:13 am | |
| I like those mockup pictures. - And funny thing I just thought about web grill aswell haha, guess i won't make one now. Great job on yours btw. | |
Doc Sprocket Site VIP
| Subject: Re: 60's Springfeild Mini Speed Tractor April 16th 2014, 12:07 am | |
| Blurg. Well got a few things done but still waiting for one part so i can start on major progress. Plug welded the 3 lug holes from the original rim and primed it. New front tires and tubes came, $45 later. Opened the 700 to make sure nothing was wrong. It looks almost brand new. Shift keys bearly have a dent in them Reverse chain was very sloppy. Removing it anyways. | |
willis923 Veteran Member
| Subject: Re: 60's Springfeild Mini Speed Tractor April 16th 2014, 1:45 pm | |
| - willis923 wrote:
- how did you get the bends in your grille? that came out really good. i wanna hear that V-twin scream
It's 1/4" rod, so just put the end in a vice and bend it be hand or adjustable pipe pliers (the ones with blue grips usually) seemed to work the best. If it had to much bend, then lay the arch on the vice and tap it with a hammer. Takes usually 2-3 times to get the angle and length right on the ends of the arch. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 16th 2014, 1:47 pm | |
It's 1/4" rod, so just put the end in a vice and bend it be hand or adjustable pipe pliers (the ones with blue grips usually) seemed to work the best. If it had to much bend, then lay the arch on the vice and tap it with a hammer. Takes usually 2-3 times to get the angle and length right on the ends of the arch. And to think... I thought you maybe used a jig or fixture, or bent the rod around a section of pipe or something... LOL | |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 16th 2014, 1:51 pm | |
| - Doc Sprocket wrote:
Nope, bend, check, bend, check, grind, tap, weld. Some pieces were longer or shorter order than that. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 16th 2014, 5:06 pm | |
| - Thunderdivine wrote:
- What size are the rears?
I dont remember, ill check later. Anyways i got some parts, tires mounted too. 4 of these 14mm heims, my spindles are metric. Tires and tubes mounted on blacked rims. And dog. Rims are .5" inches wider then tires, but worked out just fine. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 16th 2014, 7:33 pm | |
- 14mm Heim's!!! You gonna jump it? lol, that's beefy!
Bahaha, it's because of my atv spindles, the hole where the ball joint went was 14mm. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 16th 2014, 9:11 pm | |
| Looking good so far. You don't think you'll use that gas tank? Sort of looks like a racing go kart tank between your legs like that. Grill turned out really neat. What do you think you'll do about foot pegs/whatever? | |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 16th 2014, 9:27 pm | |
| - mr.modified wrote:
- Looking good so far. You don't think you'll use that gas tank? Sort of looks like a racing go kart tank between your legs like that. Grill turned out really neat. What do you think you'll do about foot pegs/whatever?
Nothing to special for floor boards, but it will all be custom. Still debating tank but i think ill get a push mower tank if i find one within reason. | |
