 60's Springfeild Mini Speed Tractor
Mitch'sgarage
GenevaCustoms
dwcopple
MurryMaddnes
Khal03
Angchor
jsisti845
untrusty huskee
T-Dub13
the craftsman mudder
Craftsman1998
jack9102
TroyBilt Pony
camomanusa
32 posters
Go to page : Previous  1, 2, 3, 4 ... 8 ... 14  Next
60's Springfeild Mini Speed Tractor  - Page 3 Empty
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 13th 2014, 6:14 pm
So what's your plan on steering?  Cool
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 13th 2014, 6:26 pm
I have one of those hubs up in VT with a 3/4" bore thats gathering dust that id be glad to give to you, but cant. Sucks for you, ha.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 13th 2014, 8:15 pm
Bah, i can get one for a few bucks. i found out the other hub is BIGGER then 1" bore. ffs, i dont know what im going to do with it
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 13th 2014, 9:59 pm
If you had a piece of pipe that fit you could weld in a sleeve to match them up. Of course if it's easier to get another one that would be better.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 13th 2014, 10:16 pm
I acually think i do have pipe but it would only change the unnder dia to 1". I could use it on my 820 but that would be a little to weak for my tastes.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 28th 2014, 8:42 pm
Anything new Red?
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 28th 2014, 8:56 pm
LAWN MOWER MUDDER wrote:
Anything new Red?
Not really. I think i have a good idea on parts i need to order
PostSubject: 60's Springfeild Mini Speed Tractor   60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 28th 2014, 8:57 pm
don't you have the tranny from the MTD?
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 28th 2014, 9:32 pm
What? I dont understand
PostSubject: 60's Springfeild Mini Speed Tractor   60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 29th 2014, 11:03 am
oh, whoops I ment to post on the mtd's thread, about your transmission with the stripped gear.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeJanuary 29th 2014, 11:23 am
No problem. Mtd needs hubs. 4x4"
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeFebruary 3rd 2014, 5:57 pm
Still no updates. Plan on ordering parts within the month becuse im lazy, ('murrrica) anyways im not sure how much $$$ it will be to finish my winch build on the mtd so when thats rockin and rollin ill get parts
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeFebruary 20th 2014, 2:31 pm
 cheers
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeMarch 30th 2014, 3:14 pm
Update!! i think i might of killed 2 birds with one stone boys....
Front brakes off a small atv, (duro maybe? No plastics on it just a sticker i saw on the handlebars) still lots of meat left on the pads! they work great and bearings are wicked smooth... 3/4" spindle
60's Springfeild Mini Speed Tractor  - Page 3 10151910
I got new front tires for the MTD, and those tires that i have on it now are the same tires im looking for, so i think i can use the 16" tall snapper tires as my rear tires on this speed mower, and the split rims (shown below)  for my front tires!
This just shows that i can re drill 4 holes in the rim but i have to be very spot on center...
60's Springfeild Mini Speed Tractor  - Page 3 18886210
60's Springfeild Mini Speed Tractor  - Page 3 15386810
I will be getting the spindles off the ATV, i didnt have a ball joint separator on hand. I have to figure out how to mount the spindles. (not hard just need bushings for the pivot bolts)
If this works, ill have much better brakes for this, so i dont have to mount any on the back, and i dont have to buy kart spindles.
Brake stands..... muhuhahaha!
Last edited by redlinemotorsportts on March 30th 2014, 11:06 pm; edited 1 time in total
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeMarch 30th 2014, 9:12 pm
Pretty nice. So your thinking of just having front brakes only you mean?
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeMarch 30th 2014, 9:16 pm
Yes, pretty much. I think ill see if cables are till there for it too
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeMarch 31st 2014, 8:05 am
Nice catch! The holes youll drill easy.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeMarch 31st 2014, 8:37 am
Yup, talked to some go kart guys on diygk, and they gave me some idea on how to make a template.... I think i will mount the original spindle from the ATV with a hem joint and a bolt that goes thru the joint and spindle.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeApril 2nd 2014, 7:43 pm
Well heres the rims with the atv drums bolted up. Really a pain in the ass to drill perfect lug holes. i make a template and everything but i guess the drill bit walks or my template wasnt 100%, so every hole seemed like it was 1/16 or less off.. had trouble getting it all center, and it still isnt super perfect. maybe a 1/32" it moves.... ill give it a try at speed and see if it really is that bad. Ill be filling in the original 3 holes.
But i gave it my best and came out  OK
60's Springfeild Mini Speed Tractor  - Page 3 19796510
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeApril 3rd 2014, 2:08 am
Looks good, maybe you just need a 101 on drilling large holes  Razz
Center punch, start with a small drill bit and so on. - looks ok tho.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeApril 3rd 2014, 6:49 am
......I did all that lol. Pretty much every thing in my power to do it to get it as spot on as possible, I only got a hand held drill.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeApril 3rd 2014, 7:39 am
Yes hand drill  Very Happy  3/16th first then slam it with the final cut. with a mix of slow - creeper gear almost.
When we drill holes before bench drills we used a rag in the hole to make it round, if not it tend to get oval'ish.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeApril 3rd 2014, 8:45 am
Like i said, i did all that. just didnt come out perfect becuse it only takes a little bit off to make it all off.
T-Dub13
T-Dub13
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeApril 3rd 2014, 12:08 pm
I use a step drill in the thin stuff like that. Makes round holes and doesn't walk. I also always center punch and center drill first. But sometimes it still comes out non-perfect unless I use a milling machine. Meh, whatever works right!
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeApril 3rd 2014, 9:10 pm
Yea i think id need a very percise template, locked down to a drill press. i center pinched, small drill bit, and then the bigger one. Oh well, ill e cleaning up the rims and then ordering some parts so i can build in spring breakin a week.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 3 Icon_minitimeApril 3rd 2014, 10:08 pm
Looks good red, I don't think you'll have any problems.
Page 3 of 14Go to page : Previous  1, 2, 3, 4 ... 8 ... 14  Next
» 60's springfeild mini tractor speed mower.
» How Do You Classify A Mini Tractor?
» Jonny's mini rat tractor
» Massimo mini tractor
» LITTLE B' - David Brown bike engined mini tractor
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2014 Archive-
