 60's Springfeild Mini Speed Tractor
Mitch'sgarage
GenevaCustoms
dwcopple
MurryMaddnes
Khal03
Angchor
jsisti845
untrusty huskee
T-Dub13
the craftsman mudder
Craftsman1998
jack9102
TroyBilt Pony
camomanusa
32 posters
Go to page : Previous  1 ... 5 ... 7, 8, 9 ... 14  Next
60's Springfeild Mini Speed Tractor  - Page 8 Empty
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 3rd 2014, 2:22 pm
It looks bendy in one pic, did it flex?
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 3rd 2014, 4:25 pm
redlinemotorsportts wrote:
21.5HP, Yea, i bet it will with my a$$ right on top of the rear tires, a wheelie bar might be in order....  tongue
Or some fancy throttle work. Should be enough horsepower for you, older VW beetle's are only 40 some hp and weigh what, a couple thousand pounds. What's this thing gonna weigh? Probably no more than 275lbs I'm guessing.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 6th 2014, 10:41 pm
I really dont know. im hoping under 200lbs. But not really a big goal.
Got the running boards totally done. Just used some pipe, and mtd footboards, few hours and its all fabbed up and very smooth.
60's Springfeild Mini Speed Tractor  - Page 8 10313311
60's Springfeild Mini Speed Tractor  - Page 8 10336610
60's Springfeild Mini Speed Tractor  - Page 8 10330310
60's Springfeild Mini Speed Tractor  - Page 8 10334410
60's Springfeild Mini Speed Tractor  - Page 8 10171114
60's Springfeild Mini Speed Tractor  - Page 8 10308210
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 7th 2014, 10:43 am
They look nice
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 7th 2014, 2:27 pm
Looks good red, did you find a big washer for the input shaft support yet?
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 7th 2014, 2:45 pm
I'm using a snapper hub to do it, it's in my previous thread before this.
camomanusa
camomanusa
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 7th 2014, 4:54 pm
Looks good so far
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 7th 2014, 10:34 pm
Running boards really are pretty neat with the pipe going around them like that. I like the idea of having holes in them, I was thinking of drilling holes in my running boards but I don't know if i'll get to it or not.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 7th 2014, 10:42 pm
Yea the holes are like punched so it kind of crowns up for grip if that makes sense. I was originally found to just weld the stock ones on but messing with the tubes wasn't to hard so I decided to make it look better.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 8th 2014, 10:09 pm
Not much to say today, but i did lock the spider gears in the rear axle. using a 210 miller matic mig. like my third time on a mig welder and damn, they dont like anything but shiny metal, PITA compared to fluxcore, where sometimes i dont even prep anything. Oh well, burned in awesome. just grinded down the excess.
60's Springfeild Mini Speed Tractor  - Page 8 10320510
Khal03
Khal03
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 9th 2014, 8:37 am
The key advantage to GMAW, to me, is that there is no spatter/slag to deal with when finished. If you can flow a clean bead you don't need to grind most jobs. A modern bicycle frame is a good example. However, I run a flux-core wire feed Lincoln for anything that wouldn't be affected by spatter/slag. On everthing I else I run a TiG unit. The best part about TiG is that you can get perfect penetration every time and the bead is never any bigger than you want/need since you feed it by hand. Like on those gears. No grinding!! Very Happy
By the way, those welds look nice, vs flux-core, as far as cleanup goes. GMAW doesn't like rust any better than grease.
What I wanna try is shielding gas over flux-core. In some fields of industry, apparently, this is done for the ULTIMATE welds with wire feed. I need a new stinger though before I can play.
Keep up the good work.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 9th 2014, 10:46 am
A lot of people don't like flux core because of what you said, the little balls of slag and the powered left over. It doesn't bother me at all, usually I finish welding and wire brush it. Then like with this build, I'll flap disk the hole frame before paint. I welded my boat trailer with the same mig and I couldn't get a clean wire burn, kept jumping because I couldn't get it all shiny metal in a notch of a bracket (rounded corner) and it was just so frustrating. I feel like flux core is the way to go with our builds, cheap, don't have to prep near as much, thinner metal work. But that's just me and my experience so far.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 11th 2014, 9:52 am
3rd bearing mounted, locked spiders in position, gunna try and swap the rear sprocket to something smaller too, stay tuned on that.
60's Springfeild Mini Speed Tractor  - Page 8 10357910
60's Springfeild Mini Speed Tractor  - Page 8 10323110
60's Springfeild Mini Speed Tractor  - Page 8 10318710
I have sense gusseted with little triangles from the green part to the flat stock that the green part is welded to for added strength
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 20th 2014, 8:59 pm
I havnt worked on it in a few days, but this is progress from last week.
Hopefully the last junkyard trip for it. New 35T rear sprocket (my original was so big, gearing was so high, and tires so small, the tranny was gunna BE a 35T.... LOL, dont even have room for that!) Mtd plastic bushings for steering shaft, buying these AFTER i got 4 oil bronze bushings that didnt fit the inner rim DIA tubes i was going to you (incredibly frustrating!!!!) and a sprocket im welding my tranny sprocket (yes got it off a MTD FNR axle and it fits!)
60's Springfeild Mini Speed Tractor  - Page 8 10275911
Got a 24T tranny sprocket.
60's Springfeild Mini Speed Tractor  - Page 8 10356610
Battery tray completed.
60's Springfeild Mini Speed Tractor  - Page 8 19028310
60's Springfeild Mini Speed Tractor  - Page 8 10269411
Steering shaft cut with the pitman arm at the bottom im probably re doing. Single bushing and bolted bracket to the motor plate.  Welded the small section on splined part on the steering shaft.
60's Springfeild Mini Speed Tractor  - Page 8 10402810
60's Springfeild Mini Speed Tractor  - Page 8 10257012
The rest of the cut steering shaft has splined parts for the steering wheel, and that shaft goes thru a 5/8" hole i drilled in some sheet metal. That small piece was welded on the bottom side to the shaft, then cut in a circle and welded to the u joint.
60's Springfeild Mini Speed Tractor  - Page 8 10336811
Strip of metal welded to the two pieces of angle iron that make up the steering colum/dash. that single bushing and sleeve will be clamped to the black strip. The long sleeve holding two bushings slid over the upper steering shaft as you can see. Brackets will hold it to the frame.
60's Springfeild Mini Speed Tractor  - Page 8 10295611
And how the steering wheel will sit. in the most comfortable position as its going to get-and it isnt that bad really!
60's Springfeild Mini Speed Tractor  - Page 8 10345910
Last edited by redlinemotorsportts on May 21st 2014, 8:00 am; edited 1 time in total
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 21st 2014, 2:55 am
24T tranny sprocket, is'nt that going to be overkill?
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 21st 2014, 7:02 am
well I'm running it gov'd, on 16's rear, and 1:1 pulleys. Math comes out to 45mph.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 21st 2014, 9:00 pm
Besides, he'll have spare gears and chains in the race hauler, just in case track conditions change...
MurryMaddnes
MurryMaddnes
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 21st 2014, 9:30 pm
Man, I really like this build, my next project might have to be something like this.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 24th 2014, 12:08 am
Thanks man, its a different build being so opposite to my offroader.
So anyways, after a bunch of measuring, finding out angles, length of throw in arms, and re checking, the steering system is done, very satisfied. Made it run under the engine, as there was no room under the chassis. The main pivot with three tie rods connecting to is from a snowmobile, witch has been chopped, and has a 7/8 bolt running through it with a jam nut locking system.
Tie rods being shortened. cut, welded, grinded down to look stock. Came out good
60's Springfeild Mini Speed Tractor  - Page 8 10338710
60's Springfeild Mini Speed Tractor  - Page 8 10298910
The piece from the snowmobile. has bushings, grease zerk, and proper ackermann effect. Trimmed and modded to work...
60's Springfeild Mini Speed Tractor  - Page 8 10363810
60's Springfeild Mini Speed Tractor  - Page 8 10417410
I get my rod ends from snowmobiles, and had these aluminum tie rods laying around left over from the snowmobile. So i bent, chopped, and re threaded the end to fit and work around the crankshaft.
60's Springfeild Mini Speed Tractor  - Page 8 10359510
Dat ackermann...
60's Springfeild Mini Speed Tractor  - Page 8 10308710
And turning radius. Witch is less then half a turn of the wheel click to click. Not super ideal, but i cant really change it. No room at all.
60's Springfeild Mini Speed Tractor  - Page 8 10363110
60's Springfeild Mini Speed Tractor  - Page 8 10346510
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 24th 2014, 7:55 am
Nice touch!
And I have that too 1/4 turn of the steering wheel is full throw.
To solve it we can move the linkage in on the ackermans or get a smaller steering wheel. (I think).
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 24th 2014, 9:57 am
I guess I'm fairly satisfied. I think with mine, I could gain just a hair more if I shortened my pitman arm. But, bleh! I'm done messing with it lol.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 24th 2014, 10:04 am
thats real nice how fast do you think its going to go
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 24th 2014, 10:10 am
If I ran my numbers right, it should be around 45mph. I'm sure it would do 60 just fine.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 24th 2014, 5:44 pm
68.3 mph on methanol/benzene blend and special super secret 14:1 heads direct from the briggs factory.
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 24th 2014, 11:22 pm
Totally, and with some horse injection.
60's Springfeild Mini Speed Tractor  - Page 8 Horse_10
PostSubject: Re: 60's Springfeild Mini Speed Tractor    60's Springfeild Mini Speed Tractor  - Page 8 Icon_minitimeMay 25th 2014, 7:52 pm
thats a cool idea has it been done
Page 8 of 14Go to page : Previous  1 ... 5 ... 7, 8, 9 ... 14  Next
» 60's springfeild mini tractor speed mower.
» How Do You Classify A Mini Tractor?
» Jonny's mini rat tractor
» Massimo mini tractor
» LITTLE B' - David Brown bike engined mini tractor
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2014 Archive-
