| 60's Springfeild Mini Speed Tractor | |
+28Mitch'sgarage GenevaCustoms dwcopple MurryMaddnes Khal03 Stretch44875 Angchor jsisti845 untrusty huskee craftsmancole kawasaki220 willis923 T-Dub13 the craftsman mudder mr.modified Doug Craftsman1998 TheBeal jack9102 LAWN MOWER MUDDER TroyBilt Pony Lawren Wimberly Doc Sprocket Thunderdivine richie thomas 1997 Murray camomanusa redlinemotorsportts 32 posters |
willis923 Veteran Member
| Subject: Re: 60's Springfeild Mini Speed Tractor April 30th 2014, 10:23 am | |
| - willis923 wrote:
- your backyard fab skills are great... you have too much time on your hands. me? i just weld it and run it...
I couldn't tell you how much I've welded on it lol. | |
Thunderdivine Veteran Member
| Subject: Re: 60's Springfeild Mini Speed Tractor April 30th 2014, 4:23 pm | |
| It's looking goooood rrrred! - I'm struggling with the hood and dash support myself. Not easy when the engine is EVERYWHERE lol. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 30th 2014, 8:38 pm | |
| Looks pretty nice and tucked in. You think you'll need any guides to stop the belt from dragging? Looks like a pretty nice setup when it's loosened up, maybe it won't need too much. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor April 30th 2014, 9:41 pm | |
| - mr.modified wrote:
- Looks pretty nice and tucked in. You think you'll need any guides to stop the belt from dragging? Looks like a pretty nice setup when it's loosened up, maybe it won't need too much.
The belt seems to stop good on the mudder right now, ill see. yea its hard to make something and still save room for steering in between the frame rails. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 1st 2014, 9:22 pm | |
| Little update. pulley system and clutch are DONE! Stock MTD parts mower clutch petal. made it more narrow, flipped the clutch foot bar at the end of it around, and grined off the original welded pieces on it off and welded the mounts to the frame. Made the clutch linkage, rod ends and adjustable. Clutch pushed in Clutch pulled out Just modified some linkage for the spring I made this a while ago, a nut welded to a bolt, ran thru a welded washer to the frame and a nut on the other side, adjustable spring. Thats for when i test drive i can control how it handles As a hole | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4576 Posts : 467 Location : Greensburg, PA
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4416 Posts : 491 Location : Index, Washington
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 1:07 am | |
- Little update. pulley system and clutch are DONE!
Young man, your practical physics intuition impresses me! | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 9:00 am | |
| - willis923 wrote:
- love that kind! gonna be moving here shortly, no?
Next step is all the steering and steering colum, some tyranny work and brakes. Still a bit ways off, but a test run shall be in order soon | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 9:41 am | |
| - willis923 wrote:
- did you ever test fire your engine?
Yea it kicked over one but didn't stay running long. Fuel pump might be bad or might not be. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 1:23 pm | |
| theyre cheap enough, get one like the one i just got, doug got one too. you can take them apart and rebuild it. only 12 bucks, free shipping | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 2:44 pm | |
| - willis923 wrote:
- theyre cheap enough, get one like the one i just got, doug got one too. you can take them apart and rebuild it. only 12 bucks, free shipping
yea, I can pull one off my other briggs twin and use that for the time being | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 6:55 pm | |
| - Thunderdivine wrote:
- lol love it, Engine with wheels.
I love the looks of it. It doesnt feel all to bad sitting on it either | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 7:03 pm | |
| yea your front axle is infront of the frame and engine therefor further forward, so you have loads of space compared to mine.
It looks well balanced, seat is infront of the rearaxle too, thats good. | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5698 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 7:24 pm | |
| - Stretch44875 wrote:
- It's got good stance. Why the diff? And are you widening the rear's to match the fronts?
I was just trying to avoid to buy a kart axle, and so far its much cheaper. i guess if this was to really chatter in a million pieces id just buy a kart axle, but i think it will work fine. will be welded posi. And no, the front extra wide stance doesnt bother me much | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 8:33 pm | |
| Hey man if I were you I'd add some triangles to that wimpy little spring retainer on the clutch pedal, I can see that thing bending when ya dump the clutch.. Just saying.. | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 8:42 pm | |
| - LAWN MOWER MUDDER wrote:
- Hey man if I were you I'd add some triangles to that wimpy little spring retainer on the clutch pedal, I can see that thing bending when ya dump the clutch.. Just saying..
Spring retainer? like the rod i welded to the petal rod? There isnt to much juping around on that side of the belt, if anything the load it has on it now is the most there ever will be. takes a little bit of force to bend that rod anyways, so i think it will be fine. Thanks though! | |
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 8:56 pm | |
| Thing really looks pretty neat when it's all put together like that. Think it'll pull the front wheels off the ground? What did you say that engine is rated for?
| Subject: Re: 60's Springfeild Mini Speed Tractor May 2nd 2014, 9:40 pm | |
- Thing really looks pretty neat when it's all put together like that. Think it'll pull the front wheels off the ground? What did you say that engine is rated for?
21.5HP, Yea, i bet it will with my a$$ right on top of the rear tires, a wheelie bar might be in order.... | |
