Got started, planned, thinkered, planned some more and cut and partially welded the rearfender/ brake mount. I was first gonna have the brake facing the back, but after a mockup and the testing it didnt really fit there, so now it will be mounted on the top of the disc.
Kinda like this when done.
Thunderdivine Veteran Member
somehow I need to sandwich this flat stock (Brake caliper holder) into the square tubing. Who said I had no fab work left.
After that I hope the sprocket and chain is around the bend, so I can get the Peerless 700 bolted down.
Still thinking on how to: do the steering column / Dash. I can't do a full width dash because then there is no room for the NOS tank and battery box/ Electronics stash.
More to come, maybe a vid later...
Struggles of a mini build! I mocked up mine a little and ended up scratching my head on where the battery and fuel tank, it will work but just a struggle of something that isn't a big issue on a full size mower.
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5149 Posts : 1068 Location : New jersey
Yea welcome to the Jungle. I'm sure you'll see it's not that easy, further down the road also. ALOT of adapting and keepin it tight together.
Craftsman1998 wrote:
Man that things going to be awesome
Thanks
This is how I vision the steering column to be fabed. - tho the angled square tubing on the other side cannot have this sway, because this is where the NOS tank will be placed - also it's not to scale, the original JD210 steering wheel is bigger than my drawing one.
So the top mount will be a cut in half wheel hub, ballraced to 3/4" BB and welded to square tubing, down to a 1/2" never used socket thingy like a u-joint in chrome vanadium, I would prefer steel, since the chrome vanadium is so friggin hard, but it'll work for steering. then down tot he other half of the wheel hub, ballraced with 5/8" bearing. VOILA NO SONG!
The steering wheel is gonna literally be in your crotch.. dont hit the brakes too hard..
Yes and No, like I said its not to scale, meaning the column and steering wheel should be bigger than the photo. - So the steering wheel will sit higher up, but not much so yeah lol
Here's a new video with me blabbering about the rear fender, and whats next. And some promised shoutout's
motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4698 Posts : 356
Sprocket 54 tooth and Carrier and 5/8" - 9 and 10 tooth sprockets with a 3/16" keyway slot for the 700. - And YES, each in one cardboard box as different shipments, from Ebay's new Global Shipping system, lol
But the 54T is almost 9 Inches across, doubt it will fit
keyway for the 700? Are you cutting your own keyway? Im going to end up having a 20+ T 700 sprocket lol
Yea I plan on doing that, but it might change. - And I think I need a 40-48T rear sprocket, (Since I want speed and not to do wheelies), but difficult to find for a #41/420 chain size and the correct ID.
This is the reason why I lowered the Peerless 700 mount.
Crouded
And if you can't tell, I ended up using the other brake disc, that came with the caliper.
I've ordered a 40 tooth sprocket, can't use this other one.
With a 40 tooth and 10 tooth on 16" Wheels @ 3600rpm, im at 42.8MPH This is with the Peerless 700 excluded. Plan on using a 15 teeth sprocket on the 700, then im @ 62.2MPH @ 3600rpm. But the peerless will change this alot so, time will show.
Doc Sprocket Site VIP
