| foot throttle project | |
cjs1029 Member
Age : 26 Join date : 2013-08-26 Points : 4158 Posts : 41 Location : galway
| Subject: foot throttle project November 24th 2013, 10:15 pm | |
| I'm using a brake lever off of an old mongoose bmx bike for a foot throttle. I have a spring for a return but I can't figure out how to attach the cable to the white plastic peice where the original cable was. Any ideas? | |
| Subject: Re: foot throttle project November 24th 2013, 10:18 pm | |
| You can run a zip tie or the bike cable (if you have enough of cable) thru the top of the plastic piece thru the bottom and just put the original cable bolt/stopper/clamp back on. | |
| Subject: Re: foot throttle project November 24th 2013, 10:22 pm | |
| Or you take the original thottle cable, cut then end off, and clamp the end of your bicycle together sorta like this Bike Cable.......................Old throttle cable ----------------------(clamp)---------------Z The Z would be the correct piece that goes into it. If your on the mobile version of the site, you may want to switch to the computer version for this.
Last edited by TroyBilt Pony on November 24th 2013, 10:23 pm; edited 1 time in total | |
| Subject: Re: foot throttle project November 24th 2013, 10:23 pm | |
| one word... PICTURES!!! these threads are about as useful as teets on a boarhog without pics... | |
| | | Doc Sprocket Site VIP
| Subject: Re: foot throttle project November 25th 2013, 6:15 am | |
| - cjs1029 wrote:
- I'm using a brake lever off of an old mongoose bmx bike for a foot throttle. I have a spring for a return but I can't figure out how to attach the cable to the white plastic peice where the original cable was. Any ideas?
Of course we have ideas! Looky here- https://www.atltf.com/t2700-adding-a-gas-pedal-my-wayx2 on the pics! | |
| | | cjs1029 Member
| Subject: Re: foot throttle project November 25th 2013, 8:39 pm | |
| Thanks doc. I'll have to do that I had the same idea for the choke. You used to original trottle lever right? | |
| Who is online? | In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests
