 Throttle Cable HELP!!
WilliesBuilds
WilliesBuilds
Throttle Cable HELP!! Empty
PostSubject: Throttle Cable HELP!!   Throttle Cable HELP!! Icon_minitimeJune 19th 2013, 9:36 pm
Im new to the ATLTF Forum and I needed help attaching the throttle cable to the carburetor. Any suggestions are much appreciated. Thanks Guys!! Throttle Cable HELP!! P6190410
PostSubject: Re: Throttle Cable HELP!!   Throttle Cable HELP!! Icon_minitimeJune 19th 2013, 9:50 pm
Need more info. What do you need help doing?
WilliesBuilds
WilliesBuilds
PostSubject: Re: Throttle Cable HELP!!   Throttle Cable HELP!! Icon_minitimeJune 19th 2013, 9:52 pm
ive been trying to post a picture but I think its up . in the photo youll see how im running it now but I need a more secure way of attaching it to the plastic part in the picture
WilliesBuilds
WilliesBuilds
PostSubject: Re: Throttle Cable HELP!!   Throttle Cable HELP!! Icon_minitimeJune 19th 2013, 9:53 pm
Throttle Cable HELP!! P6190411
motorizedeverything
motorizedeverything
PostSubject: Re: Throttle Cable HELP!!   Throttle Cable HELP!! Icon_minitimeJune 19th 2013, 10:17 pm
Feed the cable threw the hole (you may need to drill it out) and then crimp the tail of the cable to the rest of the cable (as tight as you can get it around the plastic piece). The little metal end piece on the outer sleeve of the cable need to be in the clamp.
WilliesBuilds
WilliesBuilds
PostSubject: Re: Throttle Cable HELP!!   Throttle Cable HELP!! Icon_minitimeJune 19th 2013, 10:40 pm
Thanks so much motorizedeverything !! im gonna try that out and ill post some pics afterwards and show yall
PostSubject: Re: Throttle Cable HELP!!   Throttle Cable HELP!! Icon_minitimeJune 19th 2013, 11:27 pm
The way I have mine held together is using a cable crimp, the U type with the nuts so I can adjust the slack. Less than $0.50 at Ace.
motorizedeverything
motorizedeverything
PostSubject: Re: Throttle Cable HELP!!   Throttle Cable HELP!! Icon_minitimeJune 20th 2013, 8:02 am
DO NOT drill all the way threw the plastic piece
» Is it possible to do away with the linkage setup on the side of a briggs and run your throttle cable directly to your carb?
» Porter Cable drill and circ. saw
» throttle set up
» Throttle on Briggs
» Throttle and choke clarify please?
