 Throttle on Briggs
Poulanmowerman
Poulanmowerman
Throttle on Briggs  Empty
PostSubject: Throttle on Briggs    Throttle on Briggs  Icon_minitimeDecember 4th 2013, 10:54 pm
Can u raise your throttle and will it make your mower faster it the last gear
motorizedeverything
motorizedeverything
PostSubject: Re: Throttle on Briggs    Throttle on Briggs  Icon_minitimeDecember 4th 2013, 10:58 pm
What do u mean by raise your throttle? If you mean make the engine spin faster than you will have to remove your governor. Easiest and most used way of gaining speed would be to pulley swap it
Poulanmowerman
Poulanmowerman
PostSubject: Re: Throttle on Briggs    Throttle on Briggs  Icon_minitimeDecember 4th 2013, 11:09 pm
U got to have a welder right and a new belt
mzeng100
mzeng100
PostSubject: Re: Throttle on Briggs    Throttle on Briggs  Icon_minitimeDecember 23rd 2013, 12:45 pm
You can just put a new pulley on your transaxle without welding it or anything. Just get the right size bore and put it on the shaft like the original one was. Fairly easy with the right pulley. As for the belt, you shouldnt need a new one with a slightly smaller pulley. However if the pulley is like 4 or more inches smaller then you might need a new belt. I hope this helped.
Throttle on Briggs
» Briggs Oppy foot throttle with governor
» Briggs and Stratton runs on after throttle is closed
» Briggs opposed throttle hookup help wanted.
» 18 horse briggs v-twin full throttle surge
» Is it possible to do away with the linkage setup on the side of a briggs and run your throttle cable directly to your carb?
