 Throttle and choke clarify please?
5 posters
Mark288
Mark288
Throttle and choke clarify please? Empty
PostSubject: Throttle and choke clarify please?   Throttle and choke clarify please? Icon_minitimeMarch 15th 2013, 12:21 am
Ok so basically im an idiot lol what exactly do you hook the throttle up to and the choke...im not shure if i got the throttle part u hook it into in the pic though. Please help clarify a bit thanks
Throttle and choke clarify please? Image_zpse1e1865d
PostSubject: Re: Throttle and choke clarify please?   Throttle and choke clarify please? Icon_minitimeMarch 15th 2013, 12:38 am
I have no idea what you are doing.
If you have the throttle with the choke setup, you need to isolate them. If you throttle up enough while looking in the carb, youll see one butterfly slowly close then the other will shut suddenly. That one is your choke. That you can just hook up to the old throttle cable, and just set aside the old linkage. Then you can do whatever with the throttle hookup.
BlackMountian88
BlackMountian88
PostSubject: Re: Throttle and choke clarify please?   Throttle and choke clarify please? Icon_minitimeMarch 17th 2013, 9:36 am
Like what Doug said, except you can't see the throttle butterfly without talking that carb apart! But it's an auto choke setup. I never liked those. Razz
bigboytoys98x
bigboytoys98x
PostSubject: Re: Throttle and choke clarify please?   Throttle and choke clarify please? Icon_minitimeMarch 19th 2013, 9:56 am
The sliding plastic piece is what you hook you throttle to, and ad a return spring if you are going to have a gas pedal, and hook your choke up to the first (<-------This direction) Butterfly on the caruerator. rabbit
PostSubject: Re: Throttle and choke clarify please?   Throttle and choke clarify please? Icon_minitimeMarch 19th 2013, 6:12 pm
This looks like my setup, and the choke is already hooked up, so the throttle goes to the black (painted slider) like bbt said.
If still need I can do a pic of what part tomorrow.
» Any reason for my carb to smoke from the choke side?
» Is it good to not ever have to use the choke?
» back fire through carb help
» How do I covert the choke ?
» Briggs Opposed choke
