 How do I covert the choke ?
2 posters
ripcord01
ripcord01
How do I covert the choke ? Empty
PostSubject: How do I covert the choke ?   How do I covert the choke ? Icon_minitimeJune 8th 2013, 7:18 pm
I was wondering if anyone could assist me.
I am wanting to take the throttle that is currently
on the dash and transfer it to a pedal. I have a
Poulan tractor.
Thanks,
Craig
PostSubject: Re: How do I covert the choke ?   How do I covert the choke ? Icon_minitimeJune 8th 2013, 9:09 pm
Get a good look at the mechanism on the engine. You will see that at max throttle travel, it actuates the choke. You will have to disconnect the choke from that mechanism. Then you can run your throttle how you like it. Use a separate actuating cable (maybe even the original dashmount throttle control) to tie into the choke and actuate it separately.
» Is it good to not ever have to use the choke?
» back fire through carb help
» Throttle and choke clarify please?
» Briggs Opposed choke
» Briggs & Stratton 18 Twin II will nly run on full choke
