 Any reason for my carb to smoke from the choke side?
akcender
akcender
Any reason for my carb to smoke from the choke side? Empty
PostSubject: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 14th 2011, 8:22 pm
Any reason for my carb to smoke from the choke side, i did prime it to start it by squirting gas in through there would that be the reason?
akcender
akcender
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 8:08 am
Can anyone actually help me?
ferg
ferg
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 8:09 am
Does the engine run, it could be oil coming through the breather ??
ferg
ferg
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 8:11 am
Mfipk wrote:
Buy new equipments, parts and implements of tractors from us. For more information visit our website http://mfipk.com/
I have reported you for spam....
akcender
akcender
The engine runs, its just when i shut it off that the carb smokes
ferg
ferg
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 8:15 am
Quote :
Is the smoke like a mist, and is the engine an older briggs?? if so it is just heated fuel vapour, if the engine runs fine there is nothing to be concerned about...
What engine it it???
akcender
akcender
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 1:43 pm
ferg wrote:
Quote :
Its an old 12HP tecumseh
ferg
ferg
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 2:45 pm
yeah it is normal after you have shut it down, is the smoke like a misty vapour or is it thick smoke. it would be better to give some information in the original post about the problem and engine.
akcender
akcender
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 3:52 pm
Its just a misty vapour, i probably shouldnt have called it smoke
CityRedneck
CityRedneck
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 6:48 pm
lol yea it happeneds to alot of mowers. my 21hp mower does it too. lil ploom of smoke and its fine xD
ferg
ferg
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 8:15 pm
yeah it is the fuel coming into contact with a hot surface, it turns into a wierd misty vapour. it happens on the older briggs engines and the newer ones that have no choke and only a primer. sometimes happens after shutting down the engine. nothing to worry about!!
lol I was thinking that if it was thick white smoke it means oil is going into the carb through the breather - it is soo funny when it happens, it literally makes clouds, but that only happens when the oil is overfilled by say 2x the correct amount!
gilsonrumbler
gilsonrumbler
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 15th 2011, 10:04 pm
hard to tell for me its either running too rich or the valve seats need a lapping job. i check both on mine and one or the other ends up the problem
akcender
akcender
PostSubject: Re: Any reason for my carb to smoke from the choke side?   Any reason for my carb to smoke from the choke side? Icon_minitimeDecember 16th 2011, 3:55 pm
Its OHV
» How do I covert the choke ?
» back fire through carb help
» Is it good to not ever have to use the choke?
» Project Spare Change aka Homemade Side by Side UTV
» Throttle and choke clarify please?
