| Belt slips to much | |
Kody6 Member
Age : 24 Join date : 2013-07-10 Points : 4246 Posts : 76 Location : Haileybury, ONT
| Subject: Belt slips to much September 22nd 2013, 5:21 pm | |
| I just re did my clutch on a mtd lawn tractor and put in a 6 speed trans with a 3 inche pulley and also added a tensionner pulley. but my belt keeps slipping and my belt seams tight enough. what should i do? | |
| | | k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
| | | | crazykid1994 Established Member
Age : 30 Join date : 2013-03-18 Points : 4922 Posts : 618 Location : loxahatchee, florida
| Subject: Re: Belt slips to much September 22nd 2013, 5:46 pm | |
| Did you put the right size belt? Mtd pulleys are usually 5/8 belt | |
| | | Kody6 Member
| Subject: Re: Belt slips to much September 22nd 2013, 5:47 pm | |
| - k2500life wrote:
- Is the belt worn out or flipped
no | |
| | | | Kody6 Member
| Subject: Re: Belt slips to much September 22nd 2013, 5:50 pm | |
| - crazykid1994 wrote:
- The drive pulley on the engine might be 5/8
the belt slips on the trans | |
| Subject: Re: Belt slips to much September 22nd 2013, 5:52 pm | |
| Take the pulley and rub it with sandpaper to rough it up a little. Maybe that'll help? A rough grip might help. If you put the mower in first with the clutch pushed in does it push easy? | |
| | | Kody6 Member
| Subject: Re: Belt slips to much September 22nd 2013, 5:55 pm | |
| - k2500life wrote:
- Is the rear pulley worn out
no it new | |
| | | Kody6 Member
| | | | Doc Sprocket Site VIP
| Subject: Re: Belt slips to much September 22nd 2013, 6:11 pm | |
| First, 3" is a pretty small pulley to have on the tranny. Slippage is not surprising. Second- did you put the tensioner/clutch on the correct side of the belt? Should be on the slack side, not the drive side. Got pics? | |
| Subject: Re: Belt slips to much September 22nd 2013, 6:44 pm | |
| Push the mower with it in first gear and the clutch pushed in to see how mug resistance the tyranny has. Just making sure its not seizing up | |
| | | Kody6 Member
| Subject: Re: Belt slips to much September 22nd 2013, 6:45 pm | |
| K I think I will try a 4 inch se if that is gonna be good | |
| Who is online? | In total there are 33 users online :: 0 Registered, 0 Hidden and 33 Guests
