| Clutching seperate from brakes | |
Thevinnieman92 Member
Age : 32 Join date : 2010-05-22 Points : 5339 Posts : 30 Location : Red Wing
| Subject: Clutching seperate from brakes September 6th 2010, 10:20 pm | |
| Does anyone have an idea how to clutch on the go with a manual? or how someone one would be able to make the clutch seperate from the brakes? I like riding out wheelies but cant cause when i shift the front drops done. | |
| | | arild365 Member
Age : 29 Join date : 2010-02-11 Points : 5810 Posts : 320 Location : Canada, BC
| Subject: Re: Clutching seperate from brakes September 6th 2010, 10:27 pm | |
| well with my tractor since i pulley swaped it i have to be able to shift cause theres not enough power to start in 6 gear. i dont know if its just my tractor but i can push my clutch/brake in half way and shift . ive gotten pretty good at it i also have a nother tractor that has a separate clutch an brake already | |
| | | indianaboy93 Member
Age : 31 Join date : 2010-03-14 Points : 5572 Posts : 195
| Subject: Re: Clutching seperate from brakes September 6th 2010, 10:28 pm | |
| on my manual i can hold the pedal halfway and still be going and shift. idk if its hard on the trani though | |
| Subject: Re: Clutching seperate from brakes September 6th 2010, 10:31 pm | |
| Ive tried that before and it just trys to stop, it also bind up the chain in the back causing it to sorta skip.
| | | Guest Guest
| Subject: Re: Clutching seperate from brakes September 6th 2010, 11:37 pm | |
| I make all my mowers with a a separate clutch and brake pedal, i like having brake pedal clutch pedal and throttle pedal just like a car, put the brake on the inner rite floor board and the throttle on the outer and the clutch just stays where it is. |
| | | | Guest Guest
| Subject: Re: Clutching seperate from brakes September 6th 2010, 11:48 pm | |
| - Thevinnieman92 wrote:
- Nice, how do you set. It up?
Any way that will work! Cable from the end of the pedal to the butterfly on the carb, and for the brakes i just run a rod from the pedal and then back to the stock brakes on the transaxle ( this setup is recommended for 25mph and down) anything more do a disc brake on the axle it self. I don't have any mowers with this setup rite now cause all of them are still being built, my old one that is in my icon pic is the one that had the three pedals but hade a strait axle with disc brakes cause it went 60mph, that mower is no more. My 20mph old off roader was the one with stock transaxle brakes with the pedal, i crashed that mower at full speed into a tree and flipped it so the frame was bent so i parted that out out too. Next one i build the three pedal setup on i'll take some good pics for the forum. |
| | | Guest Guest
| | | | Sponsored content
| Who is online? | In total there are 19 users online :: 0 Registered, 0 Hidden and 19 Guests
