| No spark after replacing key switch please help!!! | |
jdclevinger New Member
| Subject: No spark after replacing key switch please help!!! June 15th 2013, 11:37 am | |
| Ok I have a 03 Murray with the 12.5 power built motor. I replaced the key switch cause it wouldn't turn over. I use to be able to start it from jumping the posts of the solenoid but now I'm not gettin any spark with the new key switch all it does is crank. It was just running like a few days ago. I got the key switch from a b&s dealer so it should be the right one but would that caused my mower to loose spark. | |
| | | greener179 Member
| | | | Doug Site Owner
| Subject: Re: No spark after replacing key switch please help!!! June 15th 2013, 1:47 pm | |
| Unhook it from the coil(s) and try running it. If it still doesnt work then something else is probably wrong with your wiring. Does crossing terminals still start it up? Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | greener179 Member
| | | | Doug Site Owner
| | | | Doc Sprocket Site VIP
| | | | Marines2621 Member
Age : 27 Join date : 2012-12-31 Points : 4580 Posts : 215 Location : Mountainburg, Arkansas
| Subject: Re: No spark after replacing key switch please help!!! June 19th 2013, 3:19 pm | |
| Could be a bad coil. Or if the coil is rusty real bad it cant get spark through. Like Doug said could be bad spark plug. I check my spark by putting a screw driver were the spark plug hooks in and grounding the screw driver to a near bolt. If it doesn't spark the the coil could be bad. Try different things with it. Like sand on the magnets on the flywheel and clean the coil. See if that helps. Just throwing things out there lol! | |
| Who is online? | In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests
