 Need help replacing clutch pulleys on Craftsman
SGreenwood
SGreenwood
Need help replacing clutch pulleys on Craftsman Empty
PostSubject: Need help replacing clutch pulleys on Craftsman   Need help replacing clutch pulleys on Craftsman Icon_minitimeOctober 30th 2014, 3:41 pm
Hey guys, the manual online for my tractor (81 LTV/10 Craftsman) shows the idler and clutch pulley but however says they are discontinued so it wont even tell me the size I need. Was wondering if you guys knew or if there was a "standard" clutch and idler pulley size on these old craftsmans. Its a vertical shaft engine btw. Thanks!
fast adam
fast adam
PostSubject: Re: Need help replacing clutch pulleys on Craftsman   Need help replacing clutch pulleys on Craftsman Icon_minitimeOctober 30th 2014, 6:34 pm
you could probably find one on eBay under a different brand or try taking it to tractor supply they have a wide variety of pulleys there.
PostSubject: Re: Need help replacing clutch pulleys on Craftsman   Need help replacing clutch pulleys on Craftsman Icon_minitimeOctober 30th 2014, 6:41 pm
Take yours off and go to tractor supply, I bed you'll find one. You have to make sure it accepts the same V Wodth too, like a "wide belt reciving" pulley. Catches the belt from falling off in extreme angles/twisting
PostSubject: Re: Need help replacing clutch pulleys on Craftsman   Need help replacing clutch pulleys on Craftsman Icon_minitimeOctober 30th 2014, 7:02 pm
Agree. Most of the pulleys are in the ballpark of 3 or 4 inches. Take it off and head to your nearest tractor supply co and find one.
SGreenwood
SGreenwood
PostSubject: Re: Need help replacing clutch pulleys on Craftsman   Need help replacing clutch pulleys on Craftsman Icon_minitimeOctober 31st 2014, 9:02 am
Thanks guys, the bearing is absolutely shot in my idler and I cant keep listening to it. Tractor supply it is!
» clutch doesnt work and pulleys wont work
» What's cheaper and easier, Replacing the rings or replacing the motor with a new one?
» Using the pto clutch as a drive clutch
» No spark after replacing key switch please help!!!
» Replacing plastic spindle bushings with metal ones, have ?'s
