 Replacing plastic spindle bushings with metal ones, have ?'s
5 posters
Jerbear0612
Jerbear0612
Replacing plastic spindle bushings with metal ones, have ?'s Empty
PostSubject: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 10th 2013, 3:28 pm
Trying to replace the cruddy plastic spindle bushings with bronze metal ones. Has anyone done this and know the size offhand? Everywhere I've looked doesn't have a size that fits I almost thinks its a metric size because a 7/8 outer diameter is a hair too big and 3/4 outer is too small
dukas
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 10th 2013, 3:31 pm
Your s.o.l
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 10th 2013, 3:35 pm
If you have access to a lathe, you could turn the bigger ones down...
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Jerbear0612
Jerbear0612
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 10th 2013, 3:36 pm
Appreciate it lol, gonna have to go on mccmastercar tonight
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 10th 2013, 3:38 pm
Best way to do it is to go to a hardware store with your spindle and rim (with bushings out) and trying it out.
If you have a digital (or analog) caliper, you can measure the inside diameter of your rim and the outside diameter of your spindle and just matching numbers.
Jerbear0612
Jerbear0612
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 10th 2013, 3:43 pm
Yeah I just actually got back from trying bushings out at the hardware store, and they are the only ones that carry flange bushings around me...lowes/home depot don't carry them
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 10th 2013, 3:47 pm
What type of rims are you sing? If its a Craftsman ram with the 1 3/8 OD and 3/4" ID I would do sealed bearings.
Jerbear0612
Jerbear0612
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 11th 2013, 10:20 pm
Not looking for bearings for the rims I'm trying to replace the bushing on either end of the front axle "tube" where the spindle slides into and is c clipped on
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 11th 2013, 10:29 pm
Ah.
Same principle.
Jerbear0612
Jerbear0612
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 11th 2013, 10:49 pm
Yep taking a look through mccmastercar right now to see if they got any
Mark288
Mark288
PostSubject: Re: Replacing plastic spindle bushings with metal ones, have ?'s   Replacing plastic spindle bushings with metal ones, have ?'s Icon_minitimeMay 15th 2013, 10:00 am
Try 13/16" bronze bushings then, if they make them idk
» 820' - Replacing needle bearings with bronze bushings.
» What's cheaper and easier, Replacing the rings or replacing the motor with a new one?
» Burning Bushings?
» front bushings for my toy I mean troy
» Plastic grills
