 spicer rear end ticking noise: Mean Rabbit build
Ddwannabe
Ddwannabe
spicer rear end ticking noise: Mean Rabbit build Empty
PostSubject: spicer rear end ticking noise: Mean Rabbit build   spicer rear end ticking noise: Mean Rabbit build Icon_minitimeMarch 19th 2013, 3:06 pm
I got a spicer 6 speed transaxle
4360-7
when im riding it, it jerks and make a loud ticking noise.
it doesnt jerk or tick when im going down hill much but it jerks and ticks ALOT when im going up hill.
It does it in all the gears
SKIP TO 45 SECONDS
ANY IDEAS?
I havent takin it apart yet but id like to know what id be looking for?
mudmonkey06
mudmonkey06
PostSubject: Re: spicer rear end ticking noise: Mean Rabbit build   spicer rear end ticking noise: Mean Rabbit build Icon_minitimeMarch 19th 2013, 3:21 pm
i would go through it and make sure the mounting bolts are tight
Ddwannabe
Ddwannabe
PostSubject: spicer rear end ticking noise: Mean Rabbit build   spicer rear end ticking noise: Mean Rabbit build Icon_minitimeMarch 31st 2013, 12:06 pm
i dont think its that bc i checked and they were fine.
i herd it might be the shifting forks?
PostSubject: Re: spicer rear end ticking noise: Mean Rabbit build   spicer rear end ticking noise: Mean Rabbit build Icon_minitimeMarch 31st 2013, 12:25 pm
I would take it apart and check it anyways.
Ddwannabe
Ddwannabe
PostSubject: Mean Rabbit rear end ticking noise   spicer rear end ticking noise: Mean Rabbit build Icon_minitimeApril 16th 2013, 12:45 am
[img]spicer rear end ticking noise: Mean Rabbit build 55142611[/img]
got the rear end off
[img]spicer rear end ticking noise: Mean Rabbit build 60414411[/img]
got it open
[img]spicer rear end ticking noise: Mean Rabbit build 55502511[/img]
[img]spicer rear end ticking noise: Mean Rabbit build 72891_11[/img]
found the problem
[img]spicer rear end ticking noise: Mean Rabbit build 52529011[/img]
a broken shifting fork and a retainer ring
[img]spicer rear end ticking noise: Mean Rabbit build 55890011[/img]
cleaned it up a bit and ordered the new parts
PostSubject: Re: spicer rear end ticking noise: Mean Rabbit build   spicer rear end ticking noise: Mean Rabbit build Icon_minitimeApril 16th 2013, 1:53 am
Thatll do it!
You should convert it to oil (or at grease zerks) and replace axle seals (if they are worn) while its apart.
Ddwannabe
Ddwannabe
PostSubject: Mean Rabbit rear end ticking noise   spicer rear end ticking noise: Mean Rabbit build Icon_minitimeApril 16th 2013, 10:39 am
ya i thought about converting it but im just gonna stick with grease and i am gonna put grease zerks. the seals look good but if i can find some seals somewhere ill get them because i dont wanna order parts again because i dont want to wait for them to come.
» bbuckler's Rear Engine Offroader [2017 Build-Off Entry]
» How do I quiet down my hood and hold in place
» Transaxle noise
» Peerless MST206-545C Noise
» John Deere dif/trans noise
