| John Deere dif/trans noise | |
Otis413 New Member
Join date : 2019-06-21 Points : 2012 Posts : 15 Location : Cass, W.Va.
| Subject: John Deere dif/trans noise August 13th 2019, 5:33 pm | |
| I recently picked up a John Deere 165 Hydro for $45, it has a Kawasaki FB480v 12.5 single cyl., an Eaton(?) hydrostatic trans and a hacked up wiring harness.. A little tinkering with the carb and I got it running. Problem is, it has what sounds like a loud differential whine, sounds just like my pickup did when the pinion bearings took a dump. I'll try changing out the fluids first, but it really sounds like some bearings are about to bite the dust. Is anybody familiar with these trans-axles? I'm wondering about interchanging parts with another trans, or just swapping in a different one altogether. It's such a nice old tractor (late 80s) I hate to Off Road it (off lawn?) maybe keep the mower deck on it and swap in an L-head twin and some good ATV tires... and a push bumper... and maybe weld the dif... Anyway, any help and/or ideas would be appreciated! | |
| | | AllisKidD21 Moderator
| Subject: Re: John Deere dif/trans noise August 13th 2019, 5:45 pm | |
| I think for a hydro trans like that, the whine might just be the nature of the beast.
Changing the fluid isn't a bad idea, maybe also check make sure the level is up where is should be. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | Otis413 New Member
| Subject: Re: John Deere dif/trans noise August 13th 2019, 6:05 pm | |
| The John Deere, I checked the fluid level, it's full but looks milky... might not even be the correct oil. Another free-bee to haul off, again, some carb work and it runs great, just needs a deck belt. (maybe a seat) Another free-bee, dumped off at my house. Question: What the hell is it?? | |
| Subject: Re: John Deere dif/trans noise August 13th 2019, 7:23 pm | |
| Looks like a late 70's Murray 11hp tractor. Should have the good ol' Peerless 600 transaxle in it! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | Otis413 New Member
| Subject: Re: John Deere dif/trans noise August 13th 2019, 7:43 pm | |
| - AllisKidD21 wrote:
- Looks like a late 70's Murray 11hp tractor. Should have the good ol' Peerless 600 transaxle in it!
Make a good rat-rod project! | |
| Subject: Re: John Deere dif/trans noise August 13th 2019, 7:44 pm | |
| I would definitely have to agree! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | mrshaft696 Established Member
Join date : 2016-07-10 Points : 4061 Posts : 870 Location : Phillydelphia
| | | | Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4434 Posts : 2178 Location : North Carolina
| Subject: Re: John Deere dif/trans noise August 14th 2019, 11:28 am | |
| Ah I knew it looked familiar. Yours looks a little smaller than than the green one mrshaft. They made 2 versions of my stamped frame, an LT and a GT. You could tell be the body. The LT is made of stamped steel (like that red one), whereas the GT looks beefier with more squared floorboards (like the green one, or AK's build-off entry). Mine's just newer. Wonder what type engine the green one has or had...
I'd fix that hood on the MTD and maybe paint the deck. Could get a fair amount more out of it that way! | |
| Subject: Re: John Deere dif/trans noise August 14th 2019, 12:49 pm | |
| None of these are GT frames though, they're all LT frames including mine.. mrshaft's is just newer, that's all.
GT versions of these frames have a tunnel between the dash and fenders like Mighty's Kal El. They also don't have vertical shaft transaxles, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | | Otis413 New Member
| Subject: Re: John Deere dif/trans noise August 14th 2019, 5:19 pm | |
| In faded paint you can see "LT???" on the hood, it has a B&S 12hp under the hood, and a 3 speed/R trans. The more I think about it, yea, it's my future Rat Rod. A friend at work says he know where I can get a good L head twin cheap for my JD165 and I might just stick the Kaw engine on the old Murry.. White walls, oversized engine pulley, custom front suspension.. | |
