 Peerless MST206-545C Noise
2 posters
Vortec7622
Peerless MST206-545C Noise Empty
PostSubject: Peerless MST206-545C Noise   Peerless MST206-545C Noise Icon_minitimeApril 5th 2015, 2:38 pm
My tractor has no belt on it at the moment, but when I roll it around in neutral it makes a clicking noise at low speeds and kinda growls at walking pace. My lawn cutter has the same transaxle and is completely silent in neutral. Should I be worried?
PostSubject: Re: Peerless MST206-545C Noise   Peerless MST206-545C Noise Icon_minitimeApril 5th 2015, 7:09 pm
does it act fine with the tires in the air and you spinning the input shaft? if it all works then id say run it with caution. Its probably fine, just go slow when you first drive, or even have the tires in the air with the engine running.
Vortec7622
PostSubject: Re: Peerless MST206-545C Noise   Peerless MST206-545C Noise Icon_minitimeApril 5th 2015, 7:17 pm
With the tires in the air it takes about a half turn of the input shaft before the tires do anything
PostSubject: Re: Peerless MST206-545C Noise   Peerless MST206-545C Noise Icon_minitimeApril 5th 2015, 8:16 pm
Thats about normal.
Vortec7622
PostSubject: Re: Peerless MST206-545C Noise   Peerless MST206-545C Noise Icon_minitimeApril 5th 2015, 8:55 pm
redlinemotorsportts wrote:
Thats about normal.
Well, there's at least a little good news. It does that in all gears including reverse so I'm assuming all the gears are good.
» peerless mst206 2nd gear and reverse not workin
» What material for MST 206-545c axle replacement?
» John Deere dif/trans noise
» How do I quiet down my hood and hold in place
» Transaxle noise
