 peerless mst206 2nd gear and reverse not workin
2 posters
WilliesBuilds
WilliesBuilds
peerless mst206 2nd gear and reverse not workin Empty
PostSubject: peerless mst206 2nd gear and reverse not workin   peerless mst206 2nd gear and reverse not workin Icon_minitimeJuly 28th 2013, 6:41 pm
so when ever I shift into R it engages and then disengages same thing goes for 2nd gear its weird like if it wasn't engaging all the way almost like a slip. has anyone else had this problem ???
PostSubject: Re: peerless mst206 2nd gear and reverse not workin   peerless mst206 2nd gear and reverse not workin Icon_minitimeJuly 28th 2013, 7:36 pm
Maby the teeth are half way ripped off, check that
WilliesBuilds
WilliesBuilds
PostSubject: Re: peerless mst206 2nd gear and reverse not workin   peerless mst206 2nd gear and reverse not workin Icon_minitimeJuly 28th 2013, 8:07 pm
i did open up the case not to long ago to change the oil. everything looked fine tho, but since then its been doing that. i have a feeling it could be my shift lever not engaging all the way its the murray shifter with like the teeth on a bracket
» Peerless MST206-545C Noise
» Peerless 700 stuck in first gear
» Grease or Gear oil
» anyone lock a mtd fnr
» Mtd trans no reverse?
